Results 1 to 29 of 29
    Nov 12 2007
    2000 S4
    Boston, MA
    Boost Gauge on a stock s4?
    Is a boost gauge worth putting in a stock S4?
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Re: Boost Gauge on a stock s4?
    It couldnt hurt.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    yeah. monitor those boost leaks!
    the homebrew'd s4
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    not worth it to be honest, if it's completely stock, UNLESS you're testing for a leak or something. but other than that a stock S4 usually boosts at 13ish?
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    I have one, my car will be chipped at some point. Its just helpful to use as a trouble shooting device. The stock car will boost around 8-9psi.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    13? no. 7-9 depending on elevation.
    yes it's very worth it. you want to keep an eye on whatever your engine is doing. if you're making less boost there's a leak, and not fixing that or not knowing about it can lead to a slippery slope of more problems. bad TBB, blown turbos, etc... get it...
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Get one. Its nice to have and know that you can monitor your boost and see if something goes wrong rather than being in the dark.
    Nov 12 2007
    2000 S4
    Boston, MA
    Yes I think I will get one to monitor for problems because I have had turbo issues in the past, plus its a fairly simple install.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    lol at 13ish psi
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    I have one and i'm stock.
    Like the other's said it wont hurt and if anything will help you notice a problem much more easily.
    Look into the glowshift boost guage..
    Someone made a post with pictures a few weeks back.
    $45 shipped.
    And it looks excellent..
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    I hate mine for day in/day out driving, so I leave my hose and power connectors tucked behind the plastic plate that moves with the steering wheel adjustment.
    Zip-tied the vacuum connector. When I want to check on things, or do a track day, I hook it up (it's column mount - I wanted to keep my vents stock).
    Best of both worlds to me. But I'm not stock.
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    I got one and I'm stock.
    My VDO reads both boost and vaccum. -22-26Hg is good right?
    2015 B8 SQ5
    Click Here
    Past
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Yep, 21ish on idle & 26ish on downshifts.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    I have one and I'm stock. Get for troubleshooting and just overall monitoring of the motor. 7psi stock, with about -23hg's at idle.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Would you need 2 boost gauges for a bi-turbo?
    Apr 29 2008
    Chicago (NW)
    No, but it would be twice as accurate.
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    7-9 lbs of boost on my last stock b5 s4 was average. worth it to have.
    Nov 12 2007
    2000 S4
    Boston, MA
    what do most people have the AWE one?
    Apr 29 2008
    Chicago (NW)
    Quote Originally Posted by JWMGT90 View Post
    VDO in the NewSouth column pod
    Dec 02 2007
    DC/MD/(VA)
    42DD VDO with custom cut hole.
    Total price was $54.00
    2015 B8 SQ5
    Click Here
    Past
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    making sure things arent broken is always worth the money. get something that doesnt look like shit. ok? good.
    SBSC
    I also like to live dangerously.
    Veteran Member Three Rings Silver streak's Avatar
    Jul 14 2007
    01 S4 stage 3 AWE full kit
    Vancouver B.C.
    If you had one you wouldn't be telling people that stock boost is 13lbs!, yes you should have one 100%, if I would of had one sooner I would of discovered my throttle body boot was torn sooner.
    AWE, GIAC, Stasis,KO4s, bla bla bla this is getting a bit ridiculous. I hope it will end soon.
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    Quote Originally Posted by Overboostin View Post
    +1.
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Stage 3 Forum Advertiser Four Rings VMRSport's Avatar
    Apr 25 2008
    Irvine
    I think it is good, even for a stock car. It is almost like preventive maintenance, so you can make sure your car is running at optimal conditions.
    You should check out the gauge that we have available for your car, it gives a very OEM look:
    http://www.velocitymotoring.com/links/sport.htm
    This box does not currently receive PM's. Please direct all inquiries to Charles (VMRWheels) or Peter (Peter@VMRWheels).
    B5/B6 Audi A4 Test Pipe w/ Heat Shield
    VMR Sport | Integrated Vent Gauge Kit
    B7 Audi A4 Test Pipe - $69.99
    Established Member Two Rings audinoobs4's Avatar
    Nov 07 2007
    Chicago
    Quote Originally Posted by VMRSport View Post
    No B5 application???
    Apr 25 2008
    Irvine
    Quote Originally Posted by audinoobs4 View Post
    It is in its final stages right now actually. We are just waiting to get the final adjustments made, so that it fits just like a OEM piece.
    Feb 08 2008
    Whitestone, NY
    woops, my mistake
    $4c@b
    WGLYC
    S4SugarHips
    Veteran Member Three Rings Jurjen's Avatar
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    Just to throw in my $.02, I just found out a rip in my TBB, and I couldn't tell from the boost gauge. Im chipped, and it read normal all the way up to 15-16psi. So don't rely on your boost gauge for leaks!
    That said, I vote for Awe vent gauge - try and pick up a used one, they're a bit pricey new.
    b5 s4
    Active Member One Ring noobtuner's Avatar
    May 13 2008
    tacoma
    i run at about 5 or 6 under normal acceleration in a stock automatic A4 is that ok? i just got the New South colum kit looks great
