Thread: help with my A4
    Established Member Two Rings kmoney's Avatar
    May 11 2008
    2000 audi s4
    help with my A4
    yesterday i was just driving around and went to the car wash, i have a '98 a4 2.8 and after the wash i just started it up to head out and it seemed like it was idling really low and gonna bog out, so i just drove 50m. and then when i shifted into second the engine started to stutter when accelerating and the check engine light came on. when i just let it idle it would bog down to about 500rpm and then raise a little but it really didn't sound good and came out of nowhere. any help on what this could be would be great.
    May 11 2008
    2000 audi s4
    Re: help with my A4
    i also just got my speedtuning chip 2 weeks ago if that would have any effect ik i've heard some weird things result from it.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: help with my A4
    i think you got water in your coils/spark plugs. Take off the coils and plugs and blow them off with an air gun. Should solve your problem
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Active Member Two Rings EAGRK's Avatar
    Mar 17 2007
    1999 A4 2.8
    Fort Lee, NJ
    Re: help with my A4
    Run an vag-com on it. I had the same problem with my car, changed the coil pack, plugs, and still did it. Then I changed the fuel injectors and vag-com pulled out a code for the reference sensor. I am in the process changing the reference sensor.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: help with my A4
    sounds like a mis-fire.
    check your plugs and coils
