Results 1 to 29 of 29
    Senior Member Two Rings ekaufman's Avatar
    Jul 02 2007
    2008 Black A4 S-line
    Santa Monica
    Anyone fit an S-line grille badge on an RS4 grille?
    Im wondering if anyone has ever modified an S-line grille badge to fit the mesh on an RS4 grille. I dig the grille badge look, but Im obviously not going to put an RS4 badge on my B7 S-line.
    I think it can be done be removing and re-attaching the mounting brackets on the back of the S-line badge at the proper angle, then using the metal clips to attach it. Just wanted to know if anyone else had tried this.
    Jan 01 2008
    Indy
    Re: Anyone fit an S-line grille badge on an RS4 grille?
    I'm interested in finding a answer to this to.
    Jul 02 2007
    Santa Monica
    I see a ton of RS4 grilles, but Ive never seen one fitted with an S-line badge. The easy fix would be to buy the RS4 grille badge, carefully break off the plastic clips on the back and remount them onto a S-line badge. However, I think it can be done without buying the $40 RS4 badge.
    Jan 01 2008
    Indy
    Anyone?
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Should be able to fit the original mounts trough the mesh on the RS4 grill. Than just use some steelwire or something on the back. If they dont fit trough just grind dem down a little.
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Jul 02 2007
    Santa Monica
    So, youre saying just use the current mounts on the back of teh S-line grille? Has anyone, or could anyone test this theroy?
    Nov 24 2007
    Tromsoe, Norway
    I am not sure, but it's worth a try...
    If not, use Tec7...:)
    Jan 01 2008
    Indy
    Bump?
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Eddie Man used epoxy to mount his s4 badge on his Rs4 grille.
    Here's his simple write up.
    http://forums.audiworld.com/s4b7/msgs/47330.phtml
    Veteran Member Three Rings EuroSpec27's Avatar
    Sep 07 2009
    North Jersey
    I just installed an RS4 grille and want to mount my S-Line badge on it without using glue or epoxy. If anyone knows another way to do this (i.e. cutting the bracket off an RS4 badge) please let us know.
    '08 335xi Coupe
    Titanium/Coral
    6MT/Nav/Premium/Sport/Cold Weather
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    You will have to buy a factory RS4 grill badge then remove the rs4 and replace it with s-line that you can remove from your original. I did this with my DTM badge on my RS4/DTM grill. Same idea though.
    DSC_0034_dark1 by egritsenko, on Flickr
    22 []S6 Glacier/Arras
    19 []S4 Quantum/Magma
    16 A6 3.0T S-Line/Glacier
    15 []SQ5 Audi Exclusive/Ibis/Magma RIP
    09 []S5 V8 6MT/Ibis/Magma
    06 A4 2.0TQ StgII+ DTM/Moro
    99.5 A4 1.8T StgIII Silver
    Dec 16 2008
    Cleveland OH
    DSC_0024_1 (1) by egritsenko, on Flickr
    Sep 07 2009
    North Jersey
    Ok, awesome! What did you use to glue the badge onto the RS4 clip?
    Sep 07 2009
    North Jersey
    Also, which RS4 badge was it? I found two types on ECS:
    1.) http://www.ecstuning.com/Audi-B7_RS4...Emblem/ES5549/
    2.) http://www.ecstuning.com/Audi-B7_RS4...Emblem/ES3561/
    Thanks again!
    Oct 16 2008
    South Florida - Ft Lauderdale
    # 1
    Phil
    Senior Member Three Rings Slovak84's Avatar
    May 26 2009
    2009 B8 A5 3.2L Quattro
    New York
    Cheaper solution:
    http://cgi.ebay.com/ebaymotors/S-Lin...Q5fAccessories
    Paying 60$ for a legit RS4 badge just to peal off the RS4 logo and apply a 3m sided S-line badge that costs an additional 10$ on ebay is too expensive solution. I must admit it looks damn good though! I will post some pics of these ebay crap installed when it arrives in the mail. It is from china and costs 10$ so im not showing much optimism on this purchase. I purchased a set of 4 RS4 centercaps last year for 99 Cents....lol on ebay and when they arrived i was pretty impressed... A week later the paint peeled off and i had yellow center caps! I went to the local stealership and ended up paying 100$ for all 4 OEM ones
    Sep 07 2009
    North Jersey
    Thanks for the solution, but I'm not going to skimp on this. You get what you pay for in life, and if it means $54 for an OEM RS4 badge that will last a lifetime, it's worth it IMO.
    May 26 2009
    New York
    I will post pics and a follow up on the ebay one. Im 100% with you on "you get what you pay for" but 100$ for a grille badge Is a little over the top. The ECS RS4 badge will be my plan B if this Ebay one is not on par.
    I had the RS4 grille on for over a year and a half and it feels empty without a badge.
    Active Member Two Rings cvert's Avatar
    May 06 2010
    Moscow
    sorry for the off)
    on my machine I made in another grill fog lamps - removed the longitudinal strips, I think that was more harmonious look):
    on the topic - no icon S-Line looks ok))
    I apologize for my English)
    May 26 2009
    New York
    It was actually my first plan. But then decided I did not want to cut the lateral* strips because I want to revert back to stock when I sell car.
    Dec 16 2008
    Cleveland OH
    One in the classifieds for about half the price of a new one!
    http://www.audizine.com/classifieds/...-new-29&cat=82
    May 26 2009
    New York
    Quote Originally Posted by psiaddict85 View Post
    I purchased The RS4 badge from this dude, I got the 9$ Ebay one in the mail the other day, It looks good but i will see how both turn out and post some pics.
    Sep 07 2009
    North Jersey
    I just got my badges in the mail today and dis-assembled them, what should I use to hold the S-Line badge onto the plastic? (the OEM tape has been removed)
    May 26 2009
    New York
    I got my set-up in the mail today, I bought the RS4 badge off the dude on the classifieds and ordered a Brand new S-line badge from GOINGFAST. Got it today and the S-line badge had 3m on the back, i just stuck it on the RS4 badge bracket and looks damn good. only thing is i cant figure out how the RS4 badge clips on... i tried every angle and nearly froze to death outside before giving up!!! there is a circular piece on the back of the rs4 badge that keeps blocking the badge from fully clipping in... WTF
    May 26 2009
    New York
    Finally wedged the Mofo on:
    Dec 16 2008
    Cleveland OH
    I see you finally figured it out, haha.
    May 26 2009
    New York
    took 3 days and some frost bite
    May 26 2009
    New York
    The biggest probelm was that I put the S-line badge upside down on the Rs4 badge bracket LMAO!
    Senior Member Three Rings Rahbey's Avatar
    Feb 08 2010
    2006 A4 3.2 | 2008 Acura RDX
    looks real good slovak
    -b7 A4 3.2 Premium-
