Results 1 to 8 of 8
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    Racing Belts/Harness
    I've tried googling and searching the forums for anyone with a 4/5 point racing belt installed. I've scene pictures of the belts that clip into the back seats, rendering them useless, but allowing easy install/removal. Does anyone know where I can find these?
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Re: Racing Belts/Harness
    It sounds like you're talking about Schroth. I think they're called quick fit or something. Check out their site. Here's a link to what I think you're talking about: http://www.soloracer.com/e36rallye4.html
    the homebrew'd s4
    Dec 11 2005
    California
    Dec 05 2006
    So. Cal.
    Talk to Weeder. I saw a set in his RS4.
    Veteran Member Four Rings s6sputnik's Avatar
    95 S6 rs2//13 A6 3.0T//12 S4
    Austin Texas
    Get a 5 point NOT a 4 point!
    Shawn
    2222 & 620 Austin TX
    // 95 S6 RS2 // 13 A6 3.0T // 12 S4 3.0T
    Senior Member Two Rings B6_Rakete's Avatar
    Apr 17 2008
    '04 S4 Avant 6sp, '06 330i 6sp
    Anyone try to fit these to a B6?:
    http://www.soloracer.com/audivwrallye4.html
    The notes say the B6 and B7 chassis don't have proper anchor points:
    "AUDI NOTE: The Audi B6 and B7 chassis does not have a provision for a bolt-in harness on the out-board lap belt point. This means that you cannot safely install ANY aftermarket harness to DOT points. Installing these harnesses in a B6 or B7 chassis car will not be a Schroth Approved Installation!"
    Established Member Two Rings STaSIS_2.0T's Avatar
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    I have schroth quick fits in my car, had them installed at CPT, all the shop needs to do is modify the seat brackets and add 2 brackets in the back. Only the tabs will show and it looks like it came from the factory, very small job. These are great as you can keep your stock seats and remove/install them in less than 60secs
    STaSIS/GIAC ECU | ITG ProFilter | EvolutionRacewerks SMIC's | STaSIS exhaust | STaSIS/Koni/Vogtland suspension | STaSIS/Alcon 355mm Mono4 brakes | Volk CE-28 19x8.5 | Toyo T1-R 265/30 | O.Z. Superturismo GT 18x8 | Dunlop Wintersport 3D 235/40 | JHM short shift kit | ECS snub | RS4 rear sway | RS4 pedals | S4 shift knob | RS4 grill w/s-line chrome surround | VMR vent boost gauge | 034 Intake Pipe | CoolBoxMod | Hardwired 8500 X50 w/"OEM" mute button |
    Senior Member Three Rings JoeM's Avatar
    Nov 01 2007
    Vancouver, Wa
    any pics of the brackets they had to fab?
    -Joe-
    '08 A4 2.0T Q
    '01 Land Rover Disco II
    '99 Porsche Boxster
