Results 1 to 7 of 7
Thread: Low RPM ESP?
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    Low RPM ESP?
    Heading home tonight, I roll up to a stoplight, clutch in, and right as I am about to take it out of 3rd, light changes green. So I just clutch out and dip into the throttle about 40-50%, and I get a brief ESP engagement lighting up (the brief flashing you get in low traction situations). Was a little low in the RPM range to leave it in 3rd (maybe 1200 rpm) but it's a holiday, so I'm lazy. At any rate - it went out right away, and nothing since.
    As is always the case with the nanny lights, I'm all paranoid now. I know the MAF can trip the ESP, but everything I've found in searching hints at a solid light. This really seemed to be low RPM engagement, and I'm curious if anyone else has seen or heard anything like it?
    Stasis rebuilt with 4:1 center diff, if it helps.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: Low RPM ESP?
    Did the clutch slip? ESP will kick in for clutch slip.
    l gotta-- l gotta get
    a form from a scientist.
    Apr 29 2008
    Chicago (NW)
    Re: Low RPM ESP?
    Quote Originally Posted by TommyGunn View Post
    It's possible, as I know it was a "lazy" shift.
    I'm not too worried - haven't seen it since, but you know how it goes - the gremlins drive you crazy.
    Maybe she's just angry with me. Guess I need to start driving it like I stole it again.
    Senior Member Three Rings Ber\/ani's Avatar
    Jun 03 2007
    Sacramento CA
    Re: Low RPM ESP?
    funny this happend to me today. i took off in 2nd going like 2 mph..
    everything seems ok though. just a couple flashes then good to go.
    Apr 29 2008
    Chicago (NW)
    Re: Low RPM ESP?
    I feel better now that I know it's happening elsewhere. Or does it mean we are just both lazy chumps?
    I have a fairly new RS4 clutch, so I'm not too worried about it. YMMV
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 24 2006
    2500 dodge ram diesel
    Boston, MA
    Re: Low RPM ESP?
    happens to me too in 2nd gear going slow occasionally. not sure of the cause
    01 Casa sedan 6MT, sport, cold
    Jan 11 2007
    Salt Lake City, Utah
    Re: Low RPM ESP?
    Happens to me at the track (or at least that's when I noticed it) when I'm nowhere near losing traction. Curious of the cause as well.
