Results 1 to 21 of 21
Thread: roof antenna
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    roof antenna
    Anybody know how to take off the roof antenna? A friend and I are going to try to wrap the roof in black vinyl and want to remove it for the install. He will be using flat black but I'm thinking about using gloss black because of the shiny sunroof on my car. I feel it will flow better.
    WTB K04 turbo ASAP
    http://etektuning.com
    Sep 03 2007
    henderson, nv
    Re: roof antenna
    Bumpy bump
    WTB K04 turbo ASAP
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    Re: roof antenna
    I've been wanting to vinyl wrap my roof black as well.
    Free bump, sorry can't help ya with the roof antenna removal.
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Dec 06 2007
    Re: roof antenna
    need info as well!
    -Kirk
    BetaAlphaTau Member #58
    Sep 03 2007
    henderson, nv
    Re: roof antenna
    haha, I'm just gonna rip that sucker off! I kid I kid!
    WTB K04 turbo ASAP
    Veteran Member Three Rings plug1's Avatar
    Mar 31 2008
    Colorado Springs
    Re: roof antenna
    The shark fin? I believe there is a bolt/nut assembly under the rear interior dome light that holds this to the roof.
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    Re: roof antenna
    you have to remove the inside headliner
    Senior Member Two Rings Shi-Fu JaY's Avatar
    Apr 06 2008
    Fontana, SoCal
    Re: roof antenna
    I did mine with glossy vinyl. bought the higher end vinyl, lasts about 8 years.
    I might be able to get more vinyl, so PM if your interested.
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    Re: roof antenna
    Roof antenna is held on by a ring nut that screws down on the male threaded end from the antenna. The male end is hollow to allow the antenna wire through. It's a PITA to get to. You need to remove the rear dome light and the rear roof headliner panel to gain access. You don't need to remove the entire headliner.
    Dec 06 2007
    Re: roof antenna
    ^^this sux!
    -Kirk
    Sep 03 2007
    henderson, nv
    Re: roof antenna
    Quote Originally Posted by derleicaman View Post
    I would have never guessed that I would have to access it from the inside. that's crazy!!
    WTB K04 turbo ASAP
    Sep 03 2007
    henderson, nv
    Re: roof antenna
    Quote Originally Posted by Shi-Fu JaY View Post
    O.k it's decided then, that's exactly what I'm doing in the high gloss. Looks great!
    WTB K04 turbo ASAP
    Dec 06 2007
    Re: roof antenna
    ^^what rear lower is that?? looks like a chopped up stock rear! if so not bad!
    -Kirk
    May 21 2007
    Florida
    Re: roof antenna
    i was wondering this too. that high gloss vinyl looks sick! may do that instead of painting it black. essencially the same right? does it look painted in real life?
    2018 Navarro Blue Q5
    Sep 03 2007
    henderson, nv
    Re: roof antenna
    it should look the same as long as you do it right and take your time. probably want to leave it outside for a bit too, just to let the airbubbles dry out. Highgloss vinyl FTMFW!
    WTB K04 turbo ASAP
    May 21 2007
    Florida
    Re: roof antenna
    sweet, how much does this stuff cost and where can i get some? oh, and how do you do it? lol
    Sep 03 2007
    henderson, nv
    Re: roof antenna
    if you've never installed vinyl before you might want to have someone who has, do it for you. You have to make sure you wet down the top of your car pretty good to allow for placement of the vinyl. Get it to where you want it then start trimming it to fit. Get a vinyl squeege and start working the liquid and air bubbles to the side. Heat guns can be needed but not always. take your time and make it look nice. By the way you want to prep your paint too before applyng anything to it to get rid of dirt and dust particals.
    WTB K04 turbo ASAP
    Dec 06 2007
    Re: roof antenna
    ^^it's like window tinting!
    -Kirk
    May 21 2007
    Florida
    Re: roof antenna
    so thats it? its basically like putting on one of the headlight films? just wet it and press it down with a squeege(for the most part)? that sounds wicked easy. lol
    Dec 06 2007
    Re: roof antenna
    ^^except there are curves on ur roof so be prepared to work with it a lot!
    -Kirk
    Sep 03 2007
    henderson, nv
    Re: roof antenna
    like I said, take your time and do it right and you won't be disappointed. If you can do headlight film then you should be able to do this.
    WTB K04 turbo ASAP
