    Senior Member Two Rings detroittechno's Avatar
    Jul 02 2007
    DETROIT BURBS
    Help! How to put hose on wastegate nipple while on car
    I just finished turbo swap and car is running like shit. Looked at all my connections and noticed that the passenger side hose is not on the wastegate nipple. How in the hell can I get in there to slide the hose onto the nipple. Has clamp still on it. Also is this is what would make my car run like shit and so rich and cost me $30 a day in gas??
    Apr 10 2008
    Re: Help! How to put hose on wastegate nipple while on car
    what kind of turbo? stock or ko4s? i would c if u can get to it with a pair of long niddle nose pliers and spray some wd40 on the nipple so it slides on easier. tha will def make ur car run like shit or richer because ur turbo its not boosting. hope that helps
    Dec 06 2007
    Calgary, AB, Canada
    ^^Actually the turbo will be boosting out of control...
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    ya ,you'll overboost which isnt good. find somone with little hands. do you have any midget neighbors? maybe little kids?
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Dec 14 2007
    Motorcycles
    Bainbridge, NY
    it will also cause a vacuum leak, which is what's causing the running rough and rich.
    think about it, the MAF meters air and tells the ECU how much air is being taken into the motor, so if you've got a vac leak, you're sucking un-metered air into the motor, and the ECU cant account for that so it tries, but as a result it runs shitty.
    B6 Avant 1.8TQM - 2871RS beater. I am not a smart man.
