Results 1 to 13 of 13
    Nov 02 2007
    01 A4 QTM
    Tampa Florida FTMFW!
    car only getting to 6psi...
    i dont get it... i put in a fresh tank of 93 and my car hits 10psi... i turn it off when i get home... go out this morning and only hits 6.. this has been happening for a while now. any ideas?
    mods...
    k&n
    2.5 inch turbo back
    boost gauge
    turbo is stock
    01 QTM
    Someday....
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: car only getting to 6psi...
    limp mode?
    Apr 22 2007
    Riverbank, Ca
    and what are you using to up the boost??
    6-7psi is stock.
    Colder temperatures the car will boost lower because of the denser air. But it will still make the same HP.
    did it feel slower at 6psi?
    GL
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Andyrew, an awm is set to hit 10-11psi stock.
    check engine light on? regardless, check for codes. most local part stores (autozone, napa, advance) will do it for free.
    Apr 22 2007
    Riverbank, Ca
    Didnt notice he was 01,
    My bad!
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    <to the jaws theme>
    BAD MAF....
    BOOST LEAK...
    BAD MAF...
    BOOST LEAK...
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Feb 15 2007
    marimont
    If it's a bad maf then unplug it.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    If it's a boost leak then fix it
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    lol
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Nov 02 2007
    01 A4 QTM
    sorry guys ive been away from my pc the last few days...
    the car is still doing the same thing.. the check engine light is on for my cat (which is gone cuase of the exhaust i have) and Secondary air injection system.
    the car definitely feels slower. at 6psi then 10.
    so check the maf and do a boost leak test?
    how will i know if its the maf?
    Someday....
    Aug 29 2007
    Paktia, Afghanistan
    If you disconnect the MAF and your car runs much better than, you need a new MAF. You can also log your MAF if you've got VAG.
    Did you get your codes read again? Because even if you check engine light was already on, more codes can show up and you won't realize it because your engine light is on. Your MAF will usually throw a code. Which is why you should either, take care of whatever problem causes your check engine light so that it goes away, or check your codes on a regular basis so you know when new codes pop up.
    Do some searching, you can get rid of the code related to your cat and probably your SAI which I know little about.
    Nov 02 2007
    01 A4 QTM
    thanks man... ill go look at the codes...
    Someday....
    Aug 29 2007
    Paktia, Afghanistan
    by the way, a lot of people (including dealerships) claim that their k&n filter destroyed their MAF with the oil required on the filter. I hear the best way, is to apply a light coating and to let it sit out and dry for a day before putting it back on your car.. you may want to take this into consideration before installing a new mass air flow sensor if it turns out to be your problem.
