Results 1 to 3 of 3
    Active Member Two Rings B-Rob's Avatar
    Mar 13 2008
    Bellevue, WA
    Anybody know how to remove the cc tray?
    The Bentley manual says you have to use one special key to remove the top part of the trim above it, and then the radio keys to pull the radio out a little bit, but I don't have either one of those. I can't imagine that little bugger takes THAT much work to get out. I don't suppose anybody knows a simpler way?
    '03 A4 3.0 quattro, dolphin gray on ebony
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    Re: Anybody know how to remove the cc tray?
    hammer should do
    USP CLUB MEMBER #686
    Established Member Two Rings clcsocal's Avatar
    May 16 2008
    '04 A4 USP, '84 928S
    Santa Clarita CA
    Just changed mine out. You have to get the radio keys and pull the radio out. From there just reach in and push it out from behind. The ESP button comes out with it, it is actually attached. You will have to carefully unplug both the ESP and lighting connectors. You will have to remove the ESP button and plug it into the new CC tray.
    I bought the radio keys off Ebay for $1.99. Just search Audi radio keys. My '04 Symphony only took two keys. I think the Symphony II takes 4 keys. You really have to yank on the keys to get the radio out, but it will come out.
    Good Luck, let me know if you need more help. Check A4mods.com for pics of the radio removel, under the Ice Link DIY.
    '04 Arctic White USP 1.8T
    APR stage 1+ | Siemens 380cc | VMR TP | Clear Corners | Painted Calipers | Cupra R Lip | Euro Tails | Dension Ice Link | Apikol SMIC | Hawk HPS | K&N | Slotted & Drilled Rotors | Magnaflow | APR Snub
    "A weak list I know, but it's mine"
    USP CLUB MEMBER #112
