Results 1 to 6 of 6
Thread: ECU Pin out.
    Senior Member Three Rings Dietbudda's Avatar
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    ECU Pin out.
    Where can i find a Pin Out diag for a 1998 AEB motor with a 557 ECU.
    I need something that shows the number from the ECU and what each wire is be it a signal sender wire or a power power.
    I need to know what EACH goes to and what it dose. thank you!!
    B.A.T. coming soon...plus...
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    Re: ECU Pin out.
    Top
    Feb 27 2005
    North Wales, PA
    Re: ECU Pin out.
    i think i might have something. I'll hit you up tomorrow.
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    Re: ECU Pin out.
    Thanks poopie, anyone else?
    Nov 21 2006
    san francisco, ca
    Re: ECU Pin out.
    PM sent with the info.
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    Re: ECU Pin out.
    Thank you!!!
