Results 1 to 14 of 14
    Registered Member Two Rings ComfortRacing's Avatar
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    Question any1 have exploded view of airbox?
    hopefully you can help, i was looking for an exploded view of the b6 a4 quattro airbox.
    thanks in advance!
    2002 A4 Quattro 5-speed, KO4, SPP Ported/Polished Turbo Manifold, ATP test pipe, APR ko4 tuning, APR injectors, APR R1 DV, Front mount intercooler, H&R sport springs/Bilstein sport shocks, Neuspeed snubber mount K&N, Blackedout grille, Badgeless rear.
    To Do's:
    -APR Sport exhaust
    -Porsche seats, brakes and wheels
    -Recarro Baby seat =)
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Re: any1 have exploded view of airbox?
    ack ack ack
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    wow....another post whore.
    To Do's:
    -APR Sport exhaust
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I have an actaul air box in pieces what are you looking for?
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    i am going to modify mine, so i wanted an exploded view to see what connections still need to remain etc when i modify it. the problem with being a mechanical engineer is you cant leave well enough alone....
    To Do's:
    -APR Sport exhaust
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I see... so connections do you mean air connections, or all connections?
    For air there is only the part that screws to the MAF and the the breather connection, both visible by just looking at the air box. Also the scoop part that just slips in to the top back part.
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    most importantly things that would throw a code, i would like to tryo to run a cone filter inside with a bigger air ducting to it, either thru fender or front grille. isnt there also the dv connection to the box?
    To Do's:
    -APR Sport exhaust
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Quote Originally Posted by ComfortRacing View Post
    you could take it out and cut out any chambers or baffling that is in there
    2003 A4 1.8T
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    i wonder if it would draw more air from the bottom if i were to cut a hole in the fender and bottom of the box say 6x6 hole then place a screen to stop gravel and road grim from coming off of the tire. after looking at audi's design it looks like it is laking the cubic air space to satisfy a k04 or bigger. imo
    To Do's:
    -APR Sport exhaust
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    the airbox is plenty big enough to feed two k04's
    not a bad design really; only thing i've seen a little better is the WS6 style ram air design but that really doesn't make much of a difference until you are nearing triple digit speeds.
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    Quote Originally Posted by A4TL View Post
    i live my life quarter mile at a time - im always nearing triple digit speeds
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    at triple digit speeds the air flowing in thru the air duct system in the grille is at max velocity, actually the slower you go the less flow there is to the induction system.
    To Do's:
    -APR Sport exhaust
    Nov 06 2006
    335is
    atlanta
    remember the hose going out of the airbox into the wheel well too. its not an old-skool one-way airbox.
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    wow, see i didnt know that. that is why i want a diagram.
    To Do's:
    -APR Sport exhaust
