Results 1 to 7 of 7
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    Tapered or Conical wheel studs?
    Hey guys, just picked up a used set of Oettinger RZ 2pc 19"...
    I took off my oem stock's and put the RZ's on. I want to know if it's OK to reuse the OEM studs or should i get new one's? The oem studs feel's like they are too short when i was bolting them on. I was maybe able to get maybe 4-5 full turns from tightening. Also, i was unsure about the seat on these RZ vs OEM, are they the same? I mean tapered vs conical?
    Thanks
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Tapered or Conical wheel studs?
    the choices are ball seat or conical, since you probably increased the space between the wheel and the rotor you will need bigger bolts however 5 turns sounds sufficient to me
    Jan 21 2008
    2004 A4 1.8t Avant Sport
    Boulder, CO
    I have seen 7 turns as the standard so you might want slightly longer ones if you are worried. As for the seat type, you should be able to feel if the surface on the wheel is curved (ball/rounded seat) or if it is a straight chamfer (conical/tapered seat). The ball seat will still fit in a conical seat wheel, however the contact area will be minimal. The tire rack is a good place to get the right length and type if you need new ones.
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    ya,.. thats the problem... i felt both the oem seat and oettinger seat, and they both felt the same to me... just want someone with wheel experience for an input for the correct type of seat.
    Thanks
    Veteran Member Four Rings TooLow2.0T's Avatar
    Feb 13 2004
    Portland, OR
    Quote Originally Posted by hoking View Post
    Thanks
    If I remember correctly Oettinger wheels use a ball seat just like OEM Audi wheels, so they should look/feel the same. I don't remember if they recommend longer bolts than OEM though.
    Current: Tundra Brown 2015 Audi Q3 Prestige Quattro | Black 2013 VW Jetta
    Previous: Brilliant Red 2007 Audi A4 2.0T Quattro 6MT S-Line Titanium
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    Quote Originally Posted by TooLow2.0T View Post
    Thanks! exactly the information i was looking for. Any other inputs as to whether i need longer studs or not?
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    what are the offsets and widths
