Results 1 to 4 of 4
    Dec 14 2007
    Orange County, CA
    OEM DV to be replaced by OEM TT 225HP Version
    ...and my question is, will it run ok in "stock mode" with this different DV valve should I bring it in for service? I didn't want to get a DV that looks like something blatently aftermarket so that is why I figured with my mild APR Stage 1 tuning, that this upgraded OEM DV would work just fine...
    2004 Audi A4 1.8T Quattro Sport
    Blk/Blk, Nav RNS-E, Xenon, APR Stage 1, K&N Drop-In, RS4 Rear Sway, 710N DV Valve
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: OEM DV to be replaced by OEM TT 225HP Version
    its fine.
    you could even get the forge 007 or apr r1 and they wouldnt be able to say anything to you, unless they can PROVE that its the DV thats causing whatever problem that you brought it in for.
    Dec 25 2004
    Earth
    Been running the 710N for over 2 years with my K04! Works well!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Exact same DV
