These take a 13.5" rotor at 28mm.
If you are having trouble fitting 14" rotors under your wheels, these might be the hot ticket for you.
28mm will fade faster than 35mm's, but they also cool off faster.
If you road course your car, 355x35's m ight be a better choice.
If you AutoX, or if you're going BBK simply for weight savings/aesthetics, these might be right for you.
If the cost of a BBK is a concern, these DEFINITELY might be right for you...
The ST40 caliper used with the 14" Stoptech kit for A4's have 32mm and 38mm pistons, these calipers have 32mm and 36mm pistons. depending on your car and rear brake setup, this may be advantageous, as it adds some rear bias compared to the 32/38 calipers.
I have these ready to ship, and will send out immediately upon receipt of payment
[IMG]
