Results 1 to 12 of 12
    Established Member Two Rings baungS4's Avatar
    Jul 05 2007
    Queens,NY
    wheel cleaning help
    hi,
    I was washing my car today and used Eagle-1 A2Z Wheel and Tire cleaner my OZ ULs. It seems that the clean left some residues on my wheel that i CANNOT get off. The finish is smooth and seems like the finish now has black streaks(where the wheel cleaner was dripping off)..
    I tried using the regular car washing soap with a toothbrush and even clay bar and it didnt help.
    Any help is appreciated.
    Thanks
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    Re: wheel cleaning help
    Quote Originally Posted by baungS4 View Post
    hi,
    Thanks
    was the wheel cool or hot when you applied the wheel cleaner? they are normally for cool wheels.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Jul 05 2007
    Queens,NY
    they might have been still alittle warm. Is there anything i can do to get rid of these "stains"?
    Feb 27 2005
    North Wales, PA
    oz finish is terrible and prone to acid staining. Sounds like they need to be repainted.
    Nov 09 2005
    UBIQUITOUS
    try using polish on it. let the polish soak on the stain and rub it in. they try to rub it off. worse case, you can try Mr. Clean Magic Eraser.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Veteran Member Three Rings Twista616's Avatar
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    Quote Originally Posted by 2PUTT View Post
    Magic Eraser does wonders when used properly...be careful, it is an abrasive and will scratch your rims...dont apply alot of pressure when using it...
    "I'm right 60% of the time, all the time!"
    2005 A4 QT-SOLD // 2006 A4 QT-SOLD
    '14 SQ5 | Ibis White | 21" Stockies | More goodies in the works
    Insta: @imgarretthess Tweetness: @imgarretthess
    Jul 05 2007
    Queens,NY
    thx guys. I'll try them this wkend.
    Is it ok to just use the Adams polish(Swirl & Haze or Revive Polish)?
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    yes
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 24 2004
    try using polish like the guys said it might get rid of some of the stains on the finish of the wheels.
    you may want to also try to use something safer like P21S Wheel Cleaner.
    Stage 1 Advertiser Two Rings Mike @ einszett's Avatar
    May 03 2007
    Austin, Texas
    Quote Originally Posted by phil@detailersdomain View Post
    Or einszett Wheel Cleaner which is acid free. The Eagle One cleaners sounds like it's either too alkaline or too acidic and therefore the reason for the staining. Polish should remove it without resorting to a paint job. If a mild polish doesn't work, you might have to bump it up to a swirl reducer like Paint Polish or a fine cutting polish like Extra.
    Keep in mind that it's best to use a Wheel Cleaner only when you have a build up of brake dust or pitting. Otherwise, you a pH balance carwash shampoo to clean your wheels and paintwork.
    Mike
    einszett North America
    german waxes polishes cleaners | since 1936
    [email protected]
    www.1z-usa.com
    888-719-4698
    The einszett Detailing Guide - Articles, Terminology and More...
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Be sure to only clean your wheels when they are cool to the touch!
    Clean with P21S it is the best wheel cleaner, hands down!
    Follow-up with the clay bar, then polish, then FMJ or wheel wax.
    Registered Member Three Rings projectdarka4's Avatar
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    whats p2is???
