Results 1 to 3 of 3
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    any ideas on this code?
    How do I go about fixing this, any ideas would be great!
    coding: 0016751, wsc: 65728
    16840 : evaporative emission system
    leak detected (very small)
    [sporadic]
    WTB K04 turbo ASAP
    http://etektuning.com
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    Re: any ideas on this code?
    vacuum lines
    (1.8T n80 purge valve failing)
    check valves falling apart
    boost hoses (post maf) leak
    bad gas cap or just forgot to tighten it (trust me they do go bad!)
    most of that is just looking around for damaged hoses, any vac lines that are braided get killed by engine heat (esp turbo motors).
    n80 purge valve that doohickey that plugs in that you have to remove when you change the airbox (1.8T) - should not be able to blow through it when you take it off (blow on both ends).
    Pretty easy to debug take your time before it becomes a solid issue.
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Sep 03 2007
    henderson, nv
    coolio, thanks, I'll check it out before I drive it again. I have plenty of extra vac hoses lying around that I can change it with. and I'll check all the stupid check valves too.
    WTB K04 turbo ASAP
