Results 1 to 17 of 17
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    high pitch squeal... no codes other than misfires
    a few of you know of my hesitation problems previously....so after i changed my gaps to .024 it was running strong as hell for as long as i cld hammer it. well i was getting on it yesterday and blew the intercooler hose off. walked to a hardware store, bought a clamp and threw it on with a borrowed 2 inch screwdriver lol figured it was good enough to get home, nope, it blew off again. had a buddy bring a wrench and secured one and seemed good to go. now occasionally i hear a high pitched squeal under boost (not all the time tho). car sometimes falls into limp mode but if i restart the car it boosts fine. car will shudder here and there and lose power sometimes under boost. i havent leak tested yet as im not near my garage. im not getting any codes except my friendly 3,4 and 5 cyl misfires. does this sound like a boost leak? i did get a too high resistance on the maf a few days ago but havent gotten the code since. vag says 246 grams p/s so im assuming thats fine?? thanx for any info EDIT TO ADD CODES:::
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16688 - Cylinder 4: Misfire Detected
    P0304 - 35-00 - -
    16687 - Cylinder 3: Misfire Detected
    P0303 - 35-00 - -
    16689 - Cylinder 5: Misfire Detected
    P0305 - 35-00 - -
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    Jun 14 2007
    2000 S4
    Connecticut
    Re: high pitch squeal... no codes other than misfires
    sounds like a fuel pump to be honest man... i had the high pitch squeal on 3-, with the 5bar. if you head over to AW lately there have been a few threads about dying fuel pumps. did you ever upgrade or stock ?
    May 06 2007
    new fuel pump (stock) about a month ago. the squeal is more like the sound of compressed air passing aluminum pipe if ya know that sound lol
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    boost leak or your turbo is starting to shit the bed
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    i had a squeal when i installed my front mount.. i kpet tightening the clamps til the sound was gone..
    -Luis
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    Sounds like a leak, I put in some new ic's the other week and when I test drove her after on WOT she would squeal, so I pressure tested her and sure enough when it got up to ~15psi the squeal started, so found a tiny little leak under one of the clamps which just needed a little more tightening and problem solved. I would definately run a pressure test when you get the chance.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by S4-ORCE View Post
    you say bad turbo for EVERYTHING. [O_O].
    May 06 2007
    yeah i'll rule out bad turbo hahaha. its when i hammer it under full boost i will hear it sometimes. sometimes if i roll it on it wont make the sound or shudder. i'll leak test today.
    Dec 06 2007
    Calgary, AB, Canada
    That's just cuz he's a little jaded because his BRAND NEW turbo took a dump on him...
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by volks88 View Post
    Take that IC hose off, spray some hairspray around the IC outlet, replace hose, tighten clamp. Should solve the problem. A boost leak test won't hurt either
    May 06 2007
    leak tested and found no leaks. car is starting to act just like before. progressively getting worse. the tighter gap on the plugs seemed to help for a little longer. i think im outta this game they call stg3
    Dec 06 2007
    Calgary, AB, Canada
    No codes right? How old are the EGT and O2 sensors?
    May 06 2007
    egt's and 02's were replaced about 10k ago. heres codes i just pulled. disregard misfires lol
    P0300 - 35-00 - -
    P0304 - 35-00 - -
    P0303 - 35-00 - -
    P0305 - 35-00 - -
    May 06 2007
    also 3 days ago i got a too high resistance on the maf. i can usually roll the throttle on and it wont shudder. also i was looking around today and noticed the maf to airbox seal with the 2 clips and a o-ring was far from tight. infact it seems downright loose. could i have had a bad seal there causing a faulty maf? the o-ring seems worn and the 2 cips just doesnt seem to pull it tight to the airbox. as said before i just leak tested and found zero leaks.
    Dec 06 2007
    Calgary, AB, Canada
    zero leaks after the Y-pipe. That MAF leak would be something to fix. I would also replace the MAF. You're symptoms sound like what happens when you have a faulty MAF.
    May 06 2007
    Quote Originally Posted by The_Jerbel View Post
    yeah at this point i might as well try it. if its not it, i'll at least have an extra MAF laying around.
    Jan 30 2007
    2000 S4 stg3
    cincy
    Im have a very similar setup and am getting hesitation still and a maf too high voltage reading code. Im gonna pressure test this week and see what happens but if no boost leak Im not sure what else it could be
