Results 1 to 3 of 3
Thread: CEL Code...
    Senior Member Two Rings geoshu's Avatar
    Feb 20 2008
    '03 A4 1.8T Quattro
    Vancouver, WA
    CEL Code...
    Had Autozone run my Check engine light again, it gave the code P2181. I couldn't find anything on the Bentley manual, oddly, for my engine size. The receipt Autozone gave me suggested changing the ECT sensor and/or radiator or water pump.
    I changed the ECT sensor months back, that didnt help, and I really dont want to buy a new radiator or water pump. Anybody know what could be wrong with either? Car runs just fine, never overheats, warms up good...I'm clueless.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: CEL Code...
    P2181= cooloing system performance
    Imo
    1) Did you change the coolant temperature sensor close to the firewall?
    http://www.audiworld.com/tech/eng66.shtml
    2)TSB to replace a radiator return hose in which may contains a malfunctioning check valve.( but not sure if our a4 have one?)
    http://www.dejong947.com/audi/tsb/audi.tb.19-05-02.pdf
    hope it helps
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Feb 20 2008
    '03 A4 1.8T Quattro
    Vancouver, WA
    Re: CEL Code...
    I did change the coolant temperature sensor by the firewall, I used the write-up from a4mods.com.
    The second link mentions the car taking long to warm up, mine seems to warm up fine...but I'll double check because the light only turned on a couple days ago.
    Another thing, dont know if its related, my a/c never really blew cold, just a bit cool, it seems really weak.
