OEM B5 S4 parts
Most of the pics can be seen HERE
http://pictureposter.audiworld.com/users/114326.phtml
Exhaust manifolds $150
Down pipes $200
oem heatshields $50
front o2 sensors pretty fresh unknown miles $80
Complete a/c system make offer
Radiator $60
new style front lower c-arms (rears, the big ones) $75
corbeau front driver seat bracket make offer
Hitachi MAF housings cheap
Crankshaft make offer
full wiring harness make offer
Driver’s side cylinder head $200
Dual mass flywheel make offer
O1E transmission, works perfect $1850
O1E transmission, very worn syncros, still shifts but is rough,
it will need rebuild, great core $700
APB block only, needs re-bore from timing belt failuire nicks in cylinder make offer
wheels
SSR Comps w/ bfg drag radials. 17 x 8.5" 5 x 112mm, from b5 s4, et 35mm i believe. 4 wheels, they are a little bent, just a little bit out of perfect round. although it isnt noticeable while driving the vehicle. very very light wheels, 16.5lbs per wheel!! tires are bfg drag radials 225 45 17 and are about 40-50% percent remaining. great sticky tires that hookup great. $800
MASItaly Presidents 16" x 7.5", 4 x 108mm, two of tires are sumitomo HTRZ 2 in 205/45/16, and still have 80% remaining, the other two are toyo and def need to be replaced. Rare and disc't in the USA! $550
audi oem 17" celebrations from b5 a4, 5 wheel set w/ tire on spare. 17 x 7.5", 5 x 112mm, et 45mm, one pirelli oem 225 45 17 on the spare. with center caps $400
2 Kumho 711 tires 85% remaining 225 45 17 $100
i have 4 yokohama advan a046 tires, they have about 60% of their life left, and about 50% on the inside edge of two just because of an alignment issue, but its not drastic at all. 235 40 17 $250
Misc Items
Campbell Hausfeld WS2800 welder $200
FREE
oem battery,
email me for pics or with questions, would be willing to accept the follwing items in trade for my parts above that you may want
rs4 accordian hose
AAN Long block w/ harness and ecu
h sport sways for b5 s4
