    Account Terminated Two Rings
    Mar 12 2007
    2000 s4
    new england
    Tons of B5 parts and wheels inside!!!!!
    OEM B5 S4 parts
    Most of the pics can be seen HERE
    http://pictureposter.audiworld.com/users/114326.phtml
    Exhaust manifolds $150
    Down pipes $200
    oem heatshields $50
    front o2 sensors pretty fresh unknown miles $80
    Complete a/c system make offer
    Radiator $60
    new style front lower c-arms (rears, the big ones) $75
    corbeau front driver seat bracket make offer
    Hitachi MAF housings cheap
    Crankshaft make offer
    full wiring harness make offer
    Driver’s side cylinder head $200
    Dual mass flywheel make offer
    O1E transmission, works perfect $1850
    O1E transmission, very worn syncros, still shifts but is rough,
    it will need rebuild, great core $700
    APB block only, needs re-bore from timing belt failuire nicks in cylinder make offer
    wheels
    SSR Comps w/ bfg drag radials. 17 x 8.5" 5 x 112mm, from b5 s4, et 35mm i believe. 4 wheels, they are a little bent, just a little bit out of perfect round. although it isnt noticeable while driving the vehicle. very very light wheels, 16.5lbs per wheel!! tires are bfg drag radials 225 45 17 and are about 40-50% percent remaining. great sticky tires that hookup great. $800
    MASItaly Presidents 16" x 7.5", 4 x 108mm, two of tires are sumitomo HTRZ 2 in 205/45/16, and still have 80% remaining, the other two are toyo and def need to be replaced. Rare and disc't in the USA! $550
    audi oem 17" celebrations from b5 a4, 5 wheel set w/ tire on spare. 17 x 7.5", 5 x 112mm, et 45mm, one pirelli oem 225 45 17 on the spare. with center caps $350 obo
    2 Kumho 711 tires 85% remaining 225 45 17 $100
    i have 4 yokohama advan a046 tires, they have about 60% of their life left, and about 50% on the inside edge of two just because of an alignment issue, but its not drastic at all. 235 40 17 $250
    Misc Items
    Campbell Hausfeld WS2800 welder $200
    FREE
    oem battery,
    email me for pics or with questions, would be willing to accept the follwing items in trade for my parts above that you may want
    rs4 accordian hose
    AAN Long block w/ harness and ecu
    h sport sways for b5 s4
    Veteran Member Four Rings Turtle's Avatar
    Oct 09 2006
    Thinking......
    Los Angeles, CA
    Re: Tons of B5 parts and wheels inside!!!!!
    how much for the hsports???
    2000 Audi B5 S4 WMS RS6 Stage 3
    *Rods
    F/S: Koni Adjustable Coilovers - BNIB -$1000
    Established Member Two Rings badjoke's Avatar
    Oct 26 2007
    What condition are the wheels and tires in? Can I get pictures PMed to me?
    Mar 12 2007
    2000 s4
    new england
    Quote Originally Posted by badjoke View Post
    send me your email address and which ones you want pics of and ill get themto you
    Mar 12 2007
    2000 s4
    new england
    Quote Originally Posted by Turtle View Post
    read the ad again
