i cant send you more PMs since your mailbox is full
so here is the info you wanted:
At the time of the 1/4 mile numbers:
Generic unitronic 630cc/85mm maf file for k04s.
K04s with 55mm RS6 compressor wheels, mild porting of the exhaust side, just casting lines and stuff cleaned off.
Running an MBC set to 22psi
GHL 2.25" downpipes, cats, ASP exhaust
ER sidemounts
ECS stage3 clutch/LW FW
Custom 85mm MAF similar to the autospeed one only with a back taper so it fit the stock accordian
Evolution MS intake (old style)
Stock wheels, and some worn out FK452 tires.
track temps were 12C, too cold for launching really well. but i was getting 1.9 60 foots. Car would have hit 11s if i could have gotten out of the hole.
Ive since switched to some lighter 18" rims on falken RT615s, the X1 intake, and switched to unitronics 85mm maf with no tapering whatsoever, and an RS4 accordian hose (about 1/4 wider at the MAF)
Have not hit the track since as i have to load balance my coilovers before i try launching since i dicked around with the ride height.
