I’m also about to do my clutch in 2 weeks, I do hope you can do a write up before then, so I can have some kind of guide line to work with. I just ordered a light weight flywheel with the RS4 clutch kit; I added the upgraded disc for $50 more from vast. I’m also doing my valve cover gaskets, in all I spent $1300 for parts. I ordered some tools for the job, I would love to do the piggies, but I can’t weld & I don’t know of any shops that weld, though I’m sure there out there. I would have loved to see some pics of your install. I too will be on my back using jack stands.
How heavy is the tranny? Do I need another person or can I bring it down myself.
Did you buy new axle to hub bolts as these things “can’t be reused”?
What was the hardest part of the install?
Did you torque everything down to spec.? If you did where did you get the specs?
Sorry for all the Q’s, but I’m ready to do this job & I wanted to see if I can get a heads up on any problems to come. Thanks
