Results 1 to 13 of 13
    Nov 09 2007
    Arlington VA
    Replacing rear brake pads - need a tip
    My rear break pads are badly worn out so I got a pair of Hawk HPS and was ready to put them on yesterday but ran into a small problem - following the DIY from audiworld, you have to remove the 2 bolts that hold the caliper. The bolt on the top is a piece of cake but the one on the bottom is hidden behind the parking break wire and a bunch of other pieces from the parking break that make it impossible to access with a wrench. The only way I could make it fit is with a 4'' extension but it came at an angle and the grip wasn't too good so i was afraid not to damage the bolt.
    So how the heck do you remove that bolt ?? Do you use an open end wrench / adjustable wrench?
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    Re: Replacing rear brake pads - need a tip
    ^^I used a 13mm and 15mm
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Awaiting Confirmation Two Rings
    May 24 2008
    2003 Audi A4 3.0 Quattro, 2008
    Semi-lovely Bradford, Vermont
    Quote Originally Posted by offseri View Post
    Like "Dirty" said a 15mm and a 13mm open end, Bently manual says to remove clip on outer Pbrake cable and remove from caliper first. That's how I did mine, it was easy then. 15mm needs to be thin, craftsman wouldn't fit.
    Senior Member Three Rings pyrobecks's Avatar
    Oct 05 2006
    '06 A4 2.0TQ Prem/S-Line
    SoCal - OC
    Is there a DIY anywhere for the rear brake pad replacement?
    ~ pyrobecks
    06 A4 2.0T Quattro Tip | Premium | DTM
    Stasis SS's > RS4 Rear Sway > VM Onyx Black 19” RS4 Reps > Black Optic DTM Grill >
    Smoked Corner and Side Markers > Audi Sport Floor Mats > Euro OEM Clear Corner Xenon's > VAGged
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    When I did my ssisters 05 beattle and my A$ I just unclipped the Parking Brake cable.
    Turns into a 30 minute job
    Jusy like posted above. Though the shadetree tool MOD is awsome
    <<NO SIG>>
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    i think there is, but it's fairly easy. you take the caliper off, put the new pads in, retract the piston, and put it back.
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Oct 05 2006
    SoCal - OC
    Yup, I found one. Way easier than the fronts.
    Thanks
    ~ pyrobecks
    Oct 19 2005
    ontario
    where did you find a diy for the rear brakes
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    I didn't have to remove the bottom bolt when I did mine. I removed the top bolt, and the caliper swiveled down. Took the bads out, compressed the piston, put new pads in, tightended up both bolts just to be sure...the end.
    02 A4 - 5spd - Sport - VM DP
    Capt. Obvious - "Not me. I fart rainbows, shit rose pedals and piss excellence."
    Established Member Two Rings dtm4me's Avatar
    Mar 24 2008
    04 A4 1.8T USP APR 3+
    Atlanta GA
    SO I totally feel ur pain. I just did mine this past weekend and boy was it a pita!! (The pads and rotors were original, meaning at 50k miles they were fried)
    What u need to do is use a 13mm and a 15mm wrench to get the two bolts holding the caliper off. Use the 15mm to keep the bolt from turning. If you're swapping the rotors, you need a hex socket (not sure exactly the size) to free the two bolts holding the carrier onto the hub. The top is a piece of cake but the bottom is tough. I used a small closed end wrench over the hex socket with a small breaker bar over the wrench to free the bottom bolt....a little tough otherwise. The piston retraction was a whole diffirent story....lmk if u need help with that.
    Nothing exceeds like excess!
    USP CLUB MEMBER #103
    Senior Member Three Rings topcat's Avatar
    Apr 09 2007
    2002 A4 1.8T
    Atlanta
    ^^^^^he got broke in good on this kind of project. Ask me how I know...LOL
    Oct 29 2005
    10speed
    San Francisco, CA
    this is pretty easy.
    a 13/16" Wrench and socket will take the lower shock bolt out, swing it back, use an 8mm hex socket with a breaker bar, game over
    - Clint
    Sep 23 2006
    Houston TX
    I think the true size of that bolt is 21mm, but if 13/16 works without rounding the bolt, that's probably easier to find. The nut on the other end you'll need to hold is also 21m FWIW.
