Results 1 to 26 of 26
    Registered Member Two Rings
    Apr 06 2008
    Suburban Maryland
    Snow Chain Clearance?
    Hey... I noticed on the German Audi site that the 8 J x 17 10-spoke rims with 245/45 R17 tires -- which should be part of the U.S. Premium package -- include a notice that "the use of snow chains is not possible for technical reasons."
    Same for the 18" 5-spoke wheels which should be on the U.S. Premium-Plus package.
    I assume the "technical reasons" are clearance? Cable-type chains are pretty much unknown in Europe; they use by-God link chains that need a lot more clearance.
    And all-season tires are also very rare in Europe... these rims for the Germans have summer tires; and Germans pretty much switch to winter tires on often narrower steel rims, where chain clearance isn't a problem.
    Anyone know if the reason is indeed clearance? If so, should U.S. cable chains work?
    I know, quattro. But if you keep the all-season tires on, it'd be nice to be able to chain up occasionally when you need to...
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: Snow Chain Clearance?
    skip the chains and buy dedicated, studless snow tires!
    Nov 03 2007
    saratoga, ca
    i think it's the low profile tires. there's not enough sidewall.
    Apr 06 2008
    Suburban Maryland
    Quote Originally Posted by ngng View Post
    I know what you're saying. When I first moved to Upper Bavaria ten years ago, my Bavarian landlord took one look at the all-seasons on my 1997 U.S.-spec Passat and said what roughly translated to, "Boy, you gonna need winter tires around here." So that's what I've had on the car for the past ten years -- ZR-rated summer tires, and HR-rated snow tires on steel rims. Can't argue that that's the best way to go.
    But I'm moving to the Washington DC area, where it only snow seriously once or twice a year. (I'm originally from Seattle, so I know how driving up into the Cascades can be!) And the A4 Premium Package will come with all-season tires. Quattro with the all-seasons, and chains for emergencies on ski trips, would be the best balance.
    Quote Originally Posted by klee View Post
    More absolute sidewall than on my current 205/50's.
    But that's what's weird... there's no such warning against using chains with the 8,5J x 19 rims with 255/35R19 tires... unless they figure those are so so wide, that no self-respecting German driver is going to keep those on in the winter...
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Quote Originally Posted by Marek K View Post
    YOu're probably right about the 19" tires.
    205/50r17's will accept chains. THey primary reason is again.. clearance, but no one else mentioned, you need the clearance inside the fender well. 205/50 are narrow enough to accept them without interference inside the fender well and the suspension components.
    Jun 14 2005
    Anaheim, CA
    If you decide to play with chains - be very careful securing it down. I've seen cars with huge gouges inside the control arm, caused by too much slack on the cables. So be sure you know what you are doing :)
    Brandon @ VMR Wheels
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    i know 90% of posters here have quattros. ill be gettin a quattro next for sure.
    but for FWD owners like myself, have you guys tried the autosocks? as of now its a DOT compliant chain alternative.
    also quattro owners, please feel free to chime in.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by JeriQo View Post
    I've never had a problem with traction in my car. 9 feet of snow last year and all.
    My 2009 A4 Prem+ Build thread
    Jul 08 2015
    Quote Originally Posted by Lambda13 View Post
    same here. i kinda need to get chains for emergency or just in case i go to the mountains. (chains required)
    i went over the weekend and fortunately, the roads were plowed clean so i was able to breeze through with no problems.
    Jul 07 2012
    Boston, MA
    If you're going to the mountains where you need chains, might I suggest an extra vehicle that's made for that? lol
    Jul 08 2015
    fine. ill get an r8 next week lmao
    Jul 07 2012
    Boston, MA
    Sound logic. I'll get a Aventador, I hear they are fantastic in the snow lol
    I mean for cheap money you could get an older Tahoe/Durango/etc then sell it come spring. @Project Quattro did that a few times.
    Jul 08 2015
    the tire chains fits my budget better haha
    Jul 07 2012
    Boston, MA
    Dedicated winter setup!
    Jul 08 2015
    heres your setup!
    i dont think i can even afford the roof rack on these
    Jul 07 2012
    Boston, MA
    heres your setup!
    Sorry, I need to go change. BRB.
    Sep 01 2012
    Edmonton
    Dedicated snow tires are the way too go for sure, lot's of potential damage to your car if something goes wrong or a faulty install. If your really worried throw some studs in the winters also.
    2018 RS3 Panther Black
    Jul 08 2015
    Quote Originally Posted by WAF View Post
    winter tires arent worth it for me since im never at the pass.
    and it barely snows in the city.
    Aug 15 2014
    j what about getting just front snow tires
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    I assume you are using all-season? Keep in mind it's not so much about the snow, but the temperature. Summer and all season tires simply don't match winter or all weather tires for grip in variable, cold temperatures and road conditions. The rubber compounds are a compromise and start to decrease in performance significantly, below 7C(45F) They will also not perform well on icy roads. You may be fine coasting around the city when the weather isn't too bad. I would never drive in the mountains in winter on all season, but I live here. If you want to roll the dice for the odd trip it's of course up to you. You don't want to hit a batch of black ice on a curve on a cold day or night though! This also applies to the city, and depends on where you live, how you drive, etc. If you want a safe alternative, take a look at Nokian all weather tires(not all season) They are winter rated and perform well in summer.
    2011 A4 Avant
    Jun 23 2013
    PacNW
    Quote Originally Posted by jfo View Post
    Seconded. Winter tires improve your braking distance/handling and there is a whole genre now that cater to wet-road driving.
    Plus you get the benefit of running summer tires in the warm months which are vastly more fun and again improve braking distance/handling vs all seasons.
    Sep 01 2012
    Edmonton
    Don't listen to the Canadians they don't drive on snow...... Not sure what to say if winter tires are too much, perhaps other choices should have been.
    Jul 08 2015
    Quote Originally Posted by skis4hire View Post
    i have pirelli p6s right now and im definitely leaning towards the nokian all weathers when i replace the tires. im currently @ 12k miles
    Aug 06 2012
    Parker, CO
    That's all you need!
    Senior Member Three Rings slacktide's Avatar
    Mar 01 2015
    Seattle WA
    Quote Originally Posted by treginginco View Post
    Except when the state patrol closes the interstate to all vehicles which are not carrying chains, as they occasionally do around here. Then you are effed.
    1993 Audi 90 Quattro 2.8 5MT - Sold with 245,000 miles on it.
    2002 Audi A4 Avant Quattro 3.0 6MT - Retired commuter, Dog Car, Costco runner, Snowmobile.
    2014 Audi S4 Quattro Sport Diff 6MT - Daily Driver. CR-15, Chipwerke, minor cosmetic mods. Eventually I'll get around to the audio build.
    Jul 08 2015
    Quote Originally Posted by slacktide View Post
    i just ordered the autosock 685. at least those wont scrape my wheels and best of all, DOT approved in WA.
    thats pretty much what i need it for --- if the mountains require chains.
