Results 1 to 14 of 14
Thread: Problems
    May 24 2008
    A4 2.0T 6MT
    San Jose
    Unhappy Problems
    I read the common problem thread posted by 4flow (very good). It appears that i have a majority of the problems listed. My check engine light is on but I hooked up the code reader from autozone and I am getting codes for missfire on all 4 cylinders and a low vacume pressure code. I checked my DV because it feels like I have lost pressure but it appears to be ok. I have cleaned out my PCV and checked all my hoses and electrical plugs. The engine continues to idle rough fluctuating between 1200 and 750 rpms and the elbow of the down pipe is turning red from heat.
    The car is chipped stage 1 APR and had the forge non adjustable blowoff valve. Any ideas on what I should look at next? I would bring it to the dealer but am afraid they may void my warranty.
    07 A4 Quattro 2.0T
    Thanks
    Dec 21 2006
    West San Jose
    Re: Problems
    What a ricer
    Registered Member Two Rings
    Jul 13 2007
    Audi A4 B7 Avant
    Re: Problems
    Blowoff valve? wtf mate...
    Junior Member Two Rings Kuang87's Avatar
    Apr 01 2008
    Chicago
    Re: Problems
    First off, you need a Forge diverter valve, not a blow off one, A4's are running on a closed system that needs to recirculate the air flow. Get that blow off valve switched.
    07' Silver A4 2.0T Quattro Tiptronic
    H&R Coilovers, H&R Rear Sway Bars, Carbonio CAI,
    Milltek Exhaust, APR 93 Chip, APR FSI Fuel Pump, Forge DV, 20% Tint,Hi-flow Milltek Cat,
    AWE FMIC, and Alcon BBK
    19" Champion Motorsport RF62
    19" HRE M40
    DUH! an Audi
    los angeles, CA
    Re: Problems
    your best bet is taking your car to the dealer and make a stop at the tuner shop to get reflashed stock...
    i dont think your blow off value is causing the misfires, but like suggested replace that bov with a standard forge dv.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Re: Problems
    1) get rid of your BOV and get a DV
    May 24 2008
    A4 2.0T 6MT
    San Jose
    Re: Problems
    Quote Originally Posted by Quattro View Post
    Flash it back after the dealer fixes it?
    I have already removed the BOV. Has stock DV in place.
    Veteran Member Three Rings A4RingPimp's Avatar
    May 24 2008
    DG '06 A4/ '08 Land Rover LR2
    On a peninsula
    Re: Problems
    After hearing how SCARED everyone is about their dealer, I feel so blessed having such and awesome dealership with a Motorsports division.
    GOOD LUCK!!!!
    Sep 15 2005
    Norwalk, CA
    Re: Problems
    I think you guys are over reacting about the BOV thing. It's designed for A4 2.0t's by forge. It doesn't change how the stock DV behaves. Forge just decided to call it a "BOV" but in reality, everything is still controlled by the OEM DV.
    link
    Peter
    Established Member Two Rings smcgann's Avatar
    Apr 03 2008
    2007 A4 Quattro
    Macon GA
    Re: Problems
    This just a wild shot here but isn't there something around here about some people having problems with their coil packs? Thats one of the things that comes to mind when some one talks about misfires. Might not hurt to check for the excessive wear issue with fuel pump.
    07 A4 Quattro Quarts: APR I, K&N, RS4 sway-bar, Amp n Sub install, STaSIS Street Sports, chrome mirror caps, ECS under drive pulley, 18" R8 Reps
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    Re: Problems
    right. Vacuum pressure issues, chipped, aftermarket BOV. Check your dv to see if the diaphram is torn. That hose that's red hot could be compromised. Is the dv & bov installed properly? A coil pack would only misfire in one cylinder
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    Re: Problems
    Quote Originally Posted by guru_ck View Post
    What a ricer
    Another non-Audi owner plaging the forums with bullshit.
    May 24 2008
    A4 2.0T 6MT
    San Jose
    Re: Problems
    Quote Originally Posted by scoobycarolan View Post
    Took the DV off yesterday. The diaphram is intact. Does that unit come apart as when I pulled it out it separated where you can see the spring. I put it back together. No change.
    Everything is installed properly.
    What is the proper procedure for checking the coil pack? I am researching this now but any advice would be great.
    Thanks for all your help.
    Dec 21 2006
    West San Jose
    Re: Problems
    Actually Mr Tiesto I am a former Audi owner and the vehicle that Datalis is driving is my leased A4 that I transferred over to him. Datalis and I are roommates and I was screwing around with him so cool down bud, everything is going to be ok.
