Results 1 to 29 of 29
    Veteran Member Four Rings Smitty2A4's Avatar
    May 30 2007
    Stage 3 B5 S4 6 Speed l B6 A4 3.0 6 Speed (RIP)
    Boston, MA
    Most affordable way to drop your car without doing it half-assed?
    My A4 really needs a drop badly, just look at the picture below for proof! It is starting to bother me and after I get some body work done from an accident and my brakes upgraded I think my next point of attention will be the suspension. I don’t want to slam it, mainly just get rid of the wheel gap, is my best bet coilovers? Or getting new springs and shocks separately like from H&R or Koni? Most coilovers seem so damn expensive, and I really do not want to pay over a grand if that is possible. So what are some of my options?
    Looking for a good shop north of Boston, call Eurosport Performance
    Established Member Two Rings sonic's Avatar
    May 08 2008
    Viper
    ontario canada
    Re: Most affordable way to drop your car without doing it half-assed?
    i went with eibach spring and im extremely happy with them. nice and stiff and a good ride.
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Hack saw. J/K. Had to before someone else did.
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    ^damn i was just about to say CUT YOUR SPRINGS...but aftermarket springs would be the way to go..until you blow your stock shocks, which then you will replace them. i would just invest in used CO's or a good shock/spring combo
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Youve got many options for under a grand. Bilsteins w/ H&R springs combo would be the most affordable combo.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    pop your tires
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Registered Member Two Rings quattro2003's Avatar
    Sep 29 2007
    2003 A4 1.8T Quattro
    Pittsburgh, PA
    coilovers. Do it once, and do it right. I was in the same spot as you and i just saved the money and bought a set of coilovers. I can adjust to my preferance and raise it for the winter.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by quattro2003 View Post
    Boom... wait for used ones... A good used set will run you ~$800
    - Clint
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    OEM Sport suspension. Unless thats not enough of a drop for you, but it'll only run you about $200 then installation instead of the other methods mentioned so far. Get a 2002 or 2003 those are the best years for height but 02 is the best.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    I got a used set of springs cheap...good temporary fix if you can get the dough for coilovers before you blow your shocks
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    Just start dating a plus-size woman.
    - Although... cost of food might be more than expected
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Quote Originally Posted by Dolphin18T View Post
    2003 A4 1.8T
    Dec 18 2006
    Hanover, NH
    u need to have fat kids to weight down the back
    Marin, Ca
    +2... Don't waste your money on springs and shocks. Eventually you're going to upgrade, so you might as well do it right the first time.
    Look in the classifieds. There are normally some pretty good deals on there.
    -Tony
    '68 Datsun 520
    '71 2002 Tii
    '22 Mercedes-Benz Sprinter
    '22 RS6 Avant
    '20 L405 RR P525
    Jan 14 2008
    NEW YORK
    I think you should do Neuspeed race springs and bilstein shocks...should give you the perfect drop with no gap...should look hot 2!!
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    I'd save for COs... that's my plan.
    Mar 27 2005
    The Cold North
    Quote Originally Posted by sonic View Post
    wow. eibach & stiff in the same statement. that is kind of like saying alchoholics have healthy livers.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    May 21 2007
    Florida
    bilstien shocks with h&r sport springs-$650+install. thats where im going. since i will never adjust coilovers anyways.
    2018 Navarro Blue Q5
    Apr 16 2007
    Queens
    Quote Originally Posted by doublezero30 View Post
    Everyone aslways suggest coilovers but how many of you actually make adjustments to the coilovers on a regular basis? Everytime you want to raise and lower it youve got to take the suspension off to make adjustments then take your car to get an aligment.
    2003 A4 1.8TQM
    May 17 2007
    Quote Originally Posted by HIERLEVELZ View Post
    Not if you have Vogtland's. I just ordered a set myself.
    -Ryan
    Maestro Tuned
    Oct 29 2005
    10speed
    San Francisco, CA
    I dont get alignments lol. Ive adjusted the height 2 or 3 times and Ive messed with the damper a few times also. Its perfect right now though
    - Clint
    Veteran Member Three Rings oregonaudi's Avatar
    Oct 06 2006
    If you look hard enough (and probably wait long enough), you can find better deals. I picked up a set of Konis for 570 bucks with 4k miles. I just had to find a couple of screws and the wrench used for adjusting and I was all set.
    Modded 2003 1.8TQM - GONE
    NOW - 2007 Ibis S-Line Avant 6MT
    RAI KOR-GT ** S3 Injectors ** 034 TIP/Custom CAI ** Uni Tune ** APR HPFP ** Racetech FMIC ** 034 HFC W/ Labree Downpipe and Custom Exhaust ** BSH Stage 2 PCV Fix ** Southbend Stage 3 Daily ** DTM 25th S4 Front W/ DTM CF Splitter ** Painted Vorsteiner Hood ** iForged DTMs W/White Lips
    Sep 02 2005
    Montreal
    I only need to take off the wheels to make adjustments, which only takes about 15 minutes.
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    I'm in the same boat as you. I thought about just getting some lower springs (I'm on OEM Sport suspension which came factory installed on my Ultrasport). But, I decided that I'm gonna hold off until a great deal comes along on new Coilovers and pick up a set. I'm most interested in the KW Variant 2 Coilovers but the Stasis coilovers also seem very nice. If a great deal on either of these came along, I'd probably buy them right there and then.
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Jan 17 2008
    Vogtlands. Mine should be here next week :)
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    On my 02 with sport susp I cant slide two fingers inbetween the tire and wheelwell. There have been a few set for sale recently
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Apr 16 2007
    Queens
    Thats funny cuz my coilovers have to be remooved to make any adjustments at least the ones in the rear.
    2003 A4 1.8TQM
    Sep 29 2007
    Pittsburgh, PA
    Vogtlands. Got mine Saturday. The rears do not have to be removed to adjust them. And PureMS has a pretty good deal on them right now.
    Veteran Member Four Rings a4wheelin's Avatar
    Mar 25 2005
    '02 A4 3.0 6mt '85 Coupe GT
    Portland, OR
    Here's my '02 on OEM sport suspension and 18's. I love the ride height and the feel of the ride itself.
    1985 Audi Coupe GT 2.2L I-5 5mt (sold) :'(
    2002 A4 3.0 Quattro Sport Package 6mt
    My Photography site! bryans.smugmug.com Check it out!!!
