Results 1 to 3 of 3
    May 24 2008
    cornish,me
    cv joint replacement
    I'm replacing the cv joint on my 1999 a 4. I drove the new joint onto the axle shaft and I've hit it with heavy hammer pretty hard but it moves back and forth on the shaft about .25". I've got the axle out and in a vice so can see and hit it pretty good. It would seem like it shouldn't move.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: cv joint replacement
    Sounds like you forgot something... There is supposed to be a conical bushing that goes on first... Made out of plastic...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    What happens if you assemble with out the plastic thing?
    One of mine was split so i stuck it together anyway without the washer/conical bush, seems ok.....I think
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
