Results 1 to 4 of 4
    Veteran Member Three Rings AUDILUX's Avatar
    Oct 16 2007
    B5 S4 / 335i
    Stoptech BBK bleeder seized into caliper...
    Like the title says, I just picked up a used set of stoptech 332s and was having them installed when we found out that one of the bleeders had seized into one of the calipers. Now I am wondering if I am going to need to completely replace that caliper, have it refurbised by Stoptech of if there is some other cheaper faster fix that anyone is aware of.
    Any help would be greatly appreciated. Thanks!
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: Stoptech BBK bleeder seized into caliper...
    you dont need to, you just have to bleed them out as best as you can from the other 3 caliper bleeder ports.
    l gotta-- l gotta get
    a form from a scientist.
    Oct 16 2007
    B5 S4 / 335i
    Quote Originally Posted by TommyGunn View Post
    Actually, the bleeder pulled the thread from the caliper.
    Dec 06 2007
    Calgary, AB, Canada
    Drill and tap it, and use a spacer to screw the bleeder into.
