    Registered Member Two Rings kingo486's Avatar
    Jul 15 2007
    2001.5 Audi S4 6-Speed
    Medfield, MA & U of Dayton
    Tie Rod installation
    Im not a great mechanic or anything, but I do the work that I know I can do myself. ie; brake pads, oil changes, spark plugs... etc.
    I took my car to get an alignment and was told I need new tie rods and that it would cost like $550.
    I can get all 4 tie rods at AAP for $250. Should I buy and try to attempt doing it myself, or suck it up and pay $ that I dont want to? Is it difficult?
    2001.5 S4 6-Speed
    Brilliant Black
    GIAC Chip, RS4 Grille, 710N's, Hardwired Escort 8500
    More to come...
    Dec 06 2007
    Calgary, AB, Canada
    Re: Tie Rod installation
    4 tie rods??? There are only 2 tie rods in your car. Are you referring to the tie rod ends? Why do they want to replace the entire tie rod? Is the inner joint worn? Usually you just need to replace the outer tie rod end, which is pretty easy. You'll need an alignment afterwards though.
    Jul 15 2007
    Quote Originally Posted by The_Jerbel View Post
    Well my logic is to do both sides so I dont run into the same problem later. Pardon my wording, what I meant to say was that I plan on getting both the Inner & Outer tie rod ends for both sides of the car. Should I order on of the kits from ECS Tuning? If so, which kit should I get?
    http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T
    2001.5 S4 6-Speed
    Brilliant Black
    More to come...
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by kingo486 View Post
    The inners are a lot more work than the outers to replace. I would suggest just replacing the outer TRE's and saving the inners for later. Cross that bridge when you come to it.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Just replace the outer tie rod end. If you remove your wheel you should see that the rubber is cracked if it needs replacement. The inner tie rod should be fine and replacing it is just extra time and money. I did mine a few months ago. It's not that hard, yet plan on swearing often.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
