Results 1 to 22 of 22
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    Angry How did I get a puddle of water in my car with all the windows up!??
    So it rained really hard last night while I was at a meet made sureeee all the windows were up! As Im leaving I hear some swishing around and notice my feet are a little wet so I start feeling around (while driving) and notice my rear driver side is flooded!
    So this first thing this moring took it up ti 7-11 to vacumm the hell out of it, theres still water underneath the carpet.
    How do I get the carpet up?
    Anyone have any clue is to how this maybe had happen? Its rained harder before and no problems example (3 hurricanes)
    Any input is appreciated!
    thanks Tyler
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: How did I get a puddle of water in my car with all the windows up!??
    Sunroof drain channels are probably clogged up... Try to see where the water came from.... Should see some traces...
    ΜΟΛΩΝ ΛΑΒΕ
    Oct 08 2005
    Orlando, FL
    Yeah thats what I was thinking but wasnt 100% sure.
    thanks for the reply!
    Established Member Two Rings EOD-5's Avatar
    Apr 20 2008
    98 A4 1.8tQ, 1990 Miata
    Newark, Delaware
    mine was just leaking through the grommet in the engine bay where the hood release cable goes through.....the drain under my battery was super clogged and water was filling up 1/2 way up my battery and ecu and stuff....no good
    might want to check that, where it dripped from went right in front of my dead pedal and then into the rear for a nice puddle
    1998 Audi A4 1.8tQ 5 Speed
    VVME 4300k, RS4 Grille, GIAC, Piper Cams, APR TIP, Blinktek Heatshield, Forge FMIC, Catch Can, TurboXS BOV, PowerGasket, ECS FP Gauge, VDO Boost Gauge, ATE Slotted Rotors, PBR Pads, RubberTite Floor Mats, 034 Coil Cover
    1990 Mazda Miata
    not stock
    Oct 08 2005
    Orlando, FL
    ok Ill check that too where did you take it to get fixed? Stealership?
    Apr 20 2008
    Newark, Delaware
    no way....i just took some clear silicone from a tub and "patched" it...its held up nicely since
    1990 Mazda Miata
    not stock
    Oct 08 2005
    Orlando, FL
    I see and if its my sunroof drains just shoot some compressed air in the drains??
    Oct 08 2005
    Orlando, FL
    checked the battery and ecu area and its dry
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Quote Originally Posted by 20A4Audi1.8t01 View Post
    Here we go again...Try searching this gets asked every time it rains.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Oct 08 2005
    Orlando, FL
    here we go again??? Ive been on this forum for little over 3 years and NEVER seen a post about this so how would I know to search about this?
    if you dont have anything informative to post about DONT!
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    There is a write up some where on cleaning out the drains. It says to remove the rear bumper and run a cable up the drain toward the window.
    Also I've been on here a few months and have seen 2 or 3 (1 I created) about this same subject. They just have weird titles.
    Sold:1997 Audi A4
    Alex
    Apr 20 2008
    Newark, Delaware
    1990 Mazda Miata
    not stock
    Oct 08 2005
    Orlando, FL
    ^^THANK YOU! its your comment Burntaudi that pissed me off telling me to search when I know the routine! Just didnt think this was a common thing to happen thats all...
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Actually, this is very common, I read about it all the time. Even if you don't see it on here, it doesn't hurt to search. EOD, I hardly call that bullying him, you need to toughen up a little bit if you think asking someone to search is bullying. Also, EOD, BurntAudi was actually very nice in taking him time to post a bunch of links for the OP. I don't think the word bully means what you think it means.
    BurntAudi, I think we can agree it gets annoying.. but theres no stopping it. If people feel like answering a question that comes up all the time, then so be it. We can simply ignore threads that we think are repeated all the time.
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Mine still leaks a little. I cleared the drain under the battery made sure the hood release cable wasn't leaking, also the grommet in the ecu box. You should check the seal that connects the under hood plastic battery cover area to the windshield. Mine was pretty off and help with the water.
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Let's just get back to the subject. Who cares....we are here to resolve problems, not create them.
    Apr 20 2008
    Newark, Delaware
    Quote Originally Posted by a4 militant View Post
    seriously? "Here we go again...Try searching this gets asked every time it rains." and "You might wanna pull your head out of the sand then if you've never seen this posted before." ... i mean im glad burntaudi has the all-seeing-eye but he doesnt need to get upset at others who do not
    those two comments sound more sarcastic and assholeish and uncalled for than helpful....the 16 links he posted were more of an "i told you so" to drive his point home rather than an effort to be informative
    ive been on car forums since like 2001....im just way sick of the "use the search button" comments....theyre just not worth it....people should be on these boards to help, and generally everyone is....but why not just give a comment or an idea instead of pointing fingers and saying "search", saying that just wastes everyone's time......if he posted a few links in the first place that would have been a help...but instead it was used as retort
    and if you dont want to look at the thread then dont, like you just said you wont ....although, you are apparently knowledgeable so ignoring people in need seems a little lacking, but it does however show your maturity and how much you are willing to help people
    1990 Mazda Miata
    not stock
    Sold:1997 Audi A4
    EOD-5 I guess you have me all figured out. Just chill your the one making a bigger deal out of my posts than it needs to be. Yes I do get tried of answering the same question over and over. But I don't mind as long people at least put some effort into searching first.
    20A4Audi1.8t01 Sorry if you felt like I jumped down your throat. It does get a little old answering/seeing the same questions getting asked over and over. I was trying to be helpful posting the links to the other threads. Even with the unnecessary comment. -Peace.
    Alex
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    ^^^^^Like this hasn't happened on Audizine before.
    lol
    get back on topic!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Established Member Two Rings newtonc2001A4V6's Avatar
    Jan 23 2006
    2011 Audi A4 2.0T, 2004 Lexus RX330, 1977 MG-B
    Colorado
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by newtonc2001A4V6 View Post
    Thank you!
