I am close to pulling the mechanical and have most of my ECU and harness figured out for swapping my 2.0 BHW TDI engine from a 2005 passat into my 99 A4Q 2.8V6 chasis. I am using an '00 ARL (EDC15P) ECU complete with the 40 pin engine harness and an adapted ALH harness fo rthe 80 pin side.
Link for the project is here:
http://forums.tdiclub.com/showthread...32#post2129132
I am having trouble maching up a few existing chassis/ECU inputs with my new ECU. Specifically, on the AHA ECU there are the following inputs:
Pins 5, 19 & 45 have connections to the ABS
Pins 9, 29 & 41 are connected to the A/C system
Pin 18 is connected to the Auto check system.
I need to know specifically what each pin is for and figure out what I can do with it, or the consequences of not being able to tie them into my ECU.
Anybody have some direction on this or can lead me to a good source to resolve this? Much appreciated guys.
here is a link to my ECU spread sheet I made, if it helps:
