Results 1 to 17 of 17
    Nov 26 2007
    Vibration at idle
    Can anyone tell me if there is a solution to the heavy vibration I feel at idle on my 06 2.0t this very anoying ,didnt expect this from an Audi.It sucks.
    May 11 2008
    Naples,FL
    Re: Vibration at idle
    check your oil levels...its may need to be low or what fuel are you using and is it all the time or just the last 1/4 of the tank....or just a oil change...
    the engine is probably knocking which will happen if you are low on gas and normally theres some sediment or build up at the bottom of a tank over time..also when you need oil this sometimes happens...
    Nov 26 2007
    This car is well maintained I even had the car vagged and it shows no codes
    Registered Member Two Rings Ski DraGoN's Avatar
    Sep 24 2007
    fl
    Quote Originally Posted by 2871mds View Post
    Maybe your girlfriend is farting in your passenger seat
    Active Member Two Rings Magnus's Avatar
    Jun 29 2004
    This is a common complaint of the B7. The engine isn't sufficiently isolated from the frame. There's nothing you can do about it but you will get used to it eventually.
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    Quote Originally Posted by Ski DraGoN View Post
    hahaha better look into that one.....
    Nov 26 2007
    Would better mounts help [RS4] mounts?
    Sep 24 2007
    fl
    Registered Member Two Rings jamesmi13's Avatar
    Nov 09 2007
    Audi A4 B7
    seattle
    One cold starts my car has the same problem but once it is warm the vibration goes away Canada might be a little bit colder than seattle
    Jan 08 2008
    i had this problem too, i took it to the dealer and the "crankcase breather valve" was stuck open and they replaced it under warranty. Nice and smooth now.
    Nov 26 2007
    Thanks for the feedback 'Trust' I will definately look in to this its the best feedback ive had so far makes a whole lot of sense.
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    uhh if I remember correctly vibration at idle is common for the 2006 model but is less noticeable in 07 and 08.
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Veteran Member Three Rings A4 JooN 2.0T's Avatar
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    put it in neutral and forget about it lol
    2007 B7 A4 2.0t Qtip Brilliant Black on Black -=- Revo Stg 2/SPS2 -=- Milltek Catback Labree Quads -=- Eurocode Testpipe -=- K&N Filter -=- Forge DV -=-RS4 Rear Sway -=- ECS Quick Spool Pulley -=- Neuspeed SS -=- 20% 3M Tint -=- Lamin-X Yellow Fogs -=- LED UV Blacklight Interior Lights -=-O.Z Ultraleggera Black w/ Yokohama S.Drives
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    I noticed I my car vibrates a tad more than a loaner I have right now... I was thinking about trying Sea Foam... supposedly it works wonders and there is a DIY for this as well... any B7ers ever try it?
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    Quote Originally Posted by Sanjman View Post
    more details??
