Results 1 to 6 of 6
    Veteran Member Three Rings GetAudiHere's Avatar
    Mar 06 2006
    Minnesota
    ABS and E brake warning
    So I was driving about 60m mph about 10 minutes ago and all of a sudden I hear a beep and look down at my dash and the ABS and E brake light is alternating on with a beep. I slowed down to take a left off the highway and it went away. If it helps my CEL has been going on and off for awhile. It will stay on for a few days then go off for a few days. Could it be related?
    What does this mean? Is it serious?
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Re: ABS and E brake warning
    ABS module.
    It'll come off and on for a while, till it just stays on. Mine has been on for about 2 months, and I don't have ABS. I need to get around to sending the module out to get repaired...
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Mar 06 2006
    Minnesota
    Awesome....haha how much does that typicaly cost to repair?
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    get it rebuilt.. a lot of threads on it.. go here www.modulemaster.com
    Nov 19 2005
    WA
    Curious, but will a failed ABS pump throw a fault code?
    I know that in the Passat realm, the 00-01 model Passats have a common issue with the ABS unit, but their tach no longer works and there are a few other lights on the dash that illuminate. My ABS light stays lit and the brake light blinks, but my other cluster lights and gauges still work fine, but I do not get a code when I scan with my Vag-Com. Is it possible that one of the sensors at the wheel popped out and thats causing the ABS light to come on?
    2017 Platinum Gray Metallic Golf Alltrack SEL
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    my abs unit broke and i tried fixing it and got it half working, i occasionally get a fault code "rough road signal" or something like that.
