Originally Posted by
sCeRaXn
Are you sure the Evap purge is whats causing the ticking? That sensor is sorta near the injectors at the back of the engine, and injectors are known for that ticking noise. Heres something that might help. Take a long screwdriver and stick the end of it on the purge valve, and stick the handle to your ear. This will act like a stethoscope and allow you to hear exactly where the ticking is coming from. If the ticking isnt loud through the screwdriver, then start checking other parts in that general area to find the culprit. Good luck man.
BTW-The internal wastegate shouldnt make any ticking noises. The flapper, puck, and actuator shouldnt have any play in them, but the actuator rod will when the engine is off or if it isnt adjusted properly. If the rod is vibrating(ticking) when the car is on then it means the rod needs to be re-adjusted to have zero slack while under vacuum/boost.
what do you mean by this???
when I start the engine it makes this sound, it's a loud ticking sound , coming from the area slow4 pointed!
when I drive hard and everything is hot then it's gone , but it vibrates, and it comes from the turbo, the place that tuned my car said it was the internal wastegate of the passenger turbo that makes the sound. it only does it on the left side
when I idle the car up in rpm it's gone and when I let go off the gas it resonates like somekind of spring that tingles, it's been doing this for 10.000km's , it does not get worse or better , not even after chip and exhaust, also my car runs great and boosts properly like it should.
no garage can help me, my mechanic were i bought it doesn't know what it is , the only one that could give me an explanation was the guy who chipped my car...
