Results 1 to 40 of 55
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    tapp intake setups
    I'm about to go 3071r with a tapp tune shortly. I know one of the biggest problems with the tapp tune is dealing with the sensitive lightning maf... I would like to see pics of how people have their intakes set up and how they are routing the pcv(or running catch can) and the dv.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Sep 17 2006
    07 cbr600
    Re: tapp intake setups
    search poopie and 94jedi they have posted their pics a bunch
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    What year is your car?
    Established Member Two Rings VTECCURED's Avatar
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    hey whats up,
    i have tapp GT3071.. ford lightening maf...
    i have tried different ways of setting up , currently i have it set straight down from the turbo... and i didnt noticed any difference.
    I;m going back to my original setup and just position the maf so that the sensor is in different spots... and try that..
    i have tried putting a screen in front of the maf.. i ran lean.... i ran a screen in front and back of the sensor... and the idle was at 800 instead of 1k..
    its all about trial and error....
    GOOD LUCK>>
    john
    Feb 27 2005
    North Wales, PA
    i'm so glad i bought a 2001 for a mafless tune. Try a 4" 90* bend down to the maf and filter. a short stubby filter and I just barely miss the ac compressor.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    ^MAFless is sooooo the way to be poop. you'll enjoy it a lot! one less thing to worry about and spend money on
    btw, you going to go with Uni, or Revo?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Quote Originally Posted by t1demont1 View Post
    I was going to ask this same question lol but so far mine is working fine on the first try but it idles at 1000rpm which I think is normal on tap tune I believe??
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by sean1.8t View Post
    its either gonna be a ctapp or uni.
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by aaronamerica View Post
    tapp tune idles at 1000 rpm. that is normal
    May 31 2005
    Dallas
    I'll try to get some pics up of my lil intake setup this weekend
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    what are you guys reading for g/s at idle? im getting about 2.0-2.1
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Quote Originally Posted by bassed View Post
    99 aeb
    Sep 24 2005
    always in design
    99 aeb
    Never mind you have to run a MAF Well you could convert the MAF to MAP and all but screw that. You're going to be needing to do what Poopie recommended. The issue is you need a straight section about 2-4" long just before that 4" MAF to prevent any turbulence from interfering with the readings.
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Yeah, I figured that would be the easiest way. Are you tapp guys running a dv or not reciculating it? Also, most of you guys just running a catch can instead of running the pcv into the intake?
    Sep 24 2005
    always in design
    I'm a UNI guy. I'm a 2001.5 DBW who runs no PCV - I straight dump (was running a CatchCan but hate the smell in the cabin), no MAF and no SAI and 3" Turbo Back with no CEL UNITRONIC and 2001 FTMFW I run a BOV venting to Atmosphere.
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    How is your pcv setup to just dump?
    Sep 24 2005
    always in design
    I had a catch can setup and then simply pulled the can and open dump it. I have had no PCV for 9k miles now.
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    Quote Originally Posted by 317ssayzarc View Post
    I'm wondering the same thing .... Would like to compare to others that claim that their idle is all good and straight. Mine still have minor misses and dips at idle.
    Aeb
    Sep 17 2006
    SLC, UT
    i had it setup like that for a while. just a filter on the valve cover opening. had A LOT of oil residue in that area from it. LOTS i tell ya.
    now with the catch can, it stays clean and there is no difference in cabin smell..
    where was your catch can? between the 2 fire walls?
    Current:
    Previous:
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    This is Jakes (317ssayzarc) intake on CTapp:
    Logged a bunch of stuff today. For ex. Idle was bounding between 920-960 RPM.
    MAF values were low.
    Here are some Logs. Car pulls like a bastard.
    http://spreadsheets.google.com/pub?k...ac68MosXn4LEXQ
    http://spreadsheets.google.com/pub?k...ac50FRRaEuPGLw
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    do u have any logs of just idling at normal operating temp.??
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Nope, but at idle there were: (at operating temp)
    - no misfires
    - idle was fluctuating between 920-960
    - maf readings were ~2.1 g/s
    - 0 cyl retardation (all 4)
    - there was some timing correction but I forgot what the values were
    Sep 24 2005
    always in design
    Nope by the ABS Controler.
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    the hardest part is getting a good idle - i had some luck with using the atp TIP - that fit like crap and attaching that to the 90mm MAF and a stubby K&N - with a pretty thick fence material i found at home depot to smooth out airflow - but it is hard to get a MAF that big to get good readings - and with the very limited room under our hoods to get enough tubbing before the MAF. Trust me i probably put another + 50 bux and plus in order to get more tubbing there is just no way. I got a 90 deg bend thinking it would go down but not enough room from the frame - a 180 degree won't fit - since the pipe was like 3.75 inches in diameter.
    I just gave up - sometimes i get a good idle sometimes i don't - at least i tried
    Oct 27 2007
    In the lab
    Quote Originally Posted by nebone22 View Post
    theres the logs... theres fucking CRAZY timing pull there, and its not like overall timing is low to begin with... maybe i got the race gas file instead of pump?
    Oct 28 2006
    mmmm those are still in the acceptable range
    Established Member Two Rings Jaxspeeddemon's Avatar
    Oct 17 2006
    2001 Casablanca S4
    Jacksonville, Florida
    here is my intake, the 90* bend black silicone, air filter, and 22* bend aluminium pipe were all bought at pep boys, the 4' inch silicone and lightning maf...the whole intake setup was 225 bucks, the maf being the most expensive @ 120bucks, oh plus i have a piece of window screen before the maf. my hole intake is 4'' diameter.
    http://i50.photobucket.com/albums/f3...071intake4.jpg
    http://i50.photobucket.com/albums/f3...071intake3.jpg
    Oct 27 2007
    In the lab
    Quote Originally Posted by aytheory View Post
    15.7 degrees timing pull? i dont reccomend going over 5-6 max
    Oct 28 2006
    yah ur right - something is up - but the problems that tapp at least said is probably the MAF that is acting up cause some people buy refurb MAF that arn't calibrated that could contribute to the problem.
    Oct 17 2006
    2001 Casablanca S4
    yup most on ebay are rebuilt ones anyway, i bought mine from tapp directly!
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    is there a way to tell or test these "ebay" maf whether or not they are calibrated.
    Feb 27 2005
    North Wales, PA
    sometimes the serial numbers are ground off.
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    Quote Originally Posted by Poopie View Post
    damn..... I got mine from ebay and it had the either the part number scratched off or serial number. I'm going to log my var tomorrow.. But the only problem I have is at idle. Under normal temp. The car feels to miss fire when idling at light, or stop sign!
    I guess I'll find out as soon as I log it!
    thanks
    john
    Oct 28 2006
    sounds like the problem i had with the referb MAF
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Sam problem with Jakes car. It misfires at idle on CYl 3 (probably 5 misfires in a minute or so)
    Oct 27 2007
    In the lab
    go to bed homeslice, yous gots lots of work ahead of ya in the morning
    jk
    but yea i get misfires only after revving it then letting the revs drop, but not sitting at idle
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Quick question to you tapp users. Are you guys reciculating or venting to the atmosphere? This is pretty much the only thing I havent decided as to what im going to do on my setup.
    May 31 2005
    Dallas
    I'm actually venting mine and it runs fine for me
    Feb 27 2005
    North Wales, PA
    I haven't tried venting. If you can get away with it, I suggest it. Routing the DV line sucks.
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    at the beginning I was recirculating it, recently I have installed hks bov, and no problem. As long as the valve stays closed at idle ,,, u should be okay!
    John
