Finally, a readily available, affordable RS4 intake pipe solution for putting RS4 K04 turbos on the 2.7t.
We took matters into our own hands and have manufactured replica intake pipes that are improved over OEM units. The restrictive, redundant flow straightener has been removed, and also the tapered turbo sealing flange has been improved to seal with a smoother surface free of slag like the OE pipes are known for.
Manufactured from mild steel with a heavy duty powerder coated finish, these pipes are an exact fit for OEM, every detail even down to the vacuum routing and mounting bracket we've duplicated precisely.
Kit comes with:
(4) mild steel tubes
(4) Silicone hoses
(2) Silicone hose clamps.
Kit comes with:
(4) Silicone hoses
Please Send me a PM when you are ready to place your order.
