Originally Posted by
AWDios
I read that to test if the voice coil is the problem, you can also just try pressing on the center of the sub, and if it starts working then that's your problem.
I'm a complete electrical and audio noob, but I'm pretty sure I have this same problem, so I may have to look into resoldering to see if that helps. Happen to know of a published DIY for that? If not I'll do a search, and see.
I've never tried pressing/collapsing the voicecoil to try and see it it revives or not. I've checked a few out that way to see if I melted the voicecoils(done that a few too many times). It makes a cool noise, and sometimes if you're really lucky, it'll stick where ever you push it to.
As far as the lead to the voicecoil, I don't know of a DIY. I'd look around to see if there's an audio shop that's actually respectable(not Best buy) that could do it. That is if you're not sure what you're looking at or doing. It wouldn't be expensive if you went that route.
... The Rockford Fosgate assembly plant is about 6 miles from my house. I learned b/c I had friends that worked there.
