Originally Posted by
1.8cab
Glad to hear the upgrade worked. I only upgraded to B7 fronts and I think the pedal feel is a bit better. I can lock up my fronts now (before ABS kicks in) and I'm wondering if there's a bit of imbalance in brake bias.
I thought the master cylinders were the same. Have you heard of anyone upgrading?
B7 fronts are very similar to the B6/B7 S4 setup, so they should give you more or less the same braking power. I went with both fronts and rears at the same time and hence can't tell you whether there's a difference in bias between fronts only and fronts/rears, but I can also lock up the fronts.
I don't know if you've noticed, but before the upgrade, my rears used to dust much more than the fronts. Now, the fronts dust more than the rears. I guess that says a thing or two about the bias. In theory, your setup is front bias as of now because the B6 rears suck big time, but i think it's fine.
Jet Jockey has been looking into upgrading the master cylinder on his B6, but IIRC it's much more complicated than plug-and-play. A few have done the S4 master cylinders and have yet to publish a DIY thread.
