Results 1 to 15 of 15
    Veteran Member Four Rings michgo's Avatar
    Oct 21 2007
    Wagon/Variant/Avant A4 B6
    Question Quick question for you guys! (USP help needed)
    So i gave my local dealer a call (Penske Audi ) and tried to get some USP sideskirts. Guy was very helpful and we found out everything I needed except he brought up a part I didnt know if I needed or not.
    On the USP sideskirts (OEM) what part is the "end cap". Supposedly its right before the rear wheel well and fender. Question is, do I need this part? And will these fit up onto my non-USP a4?
    Thanks for your help guys!
    I heart wagons.
    'It's actually a pretty big pet peeve of mine when people mess around with my photos', MmmBoost
    shave it mold it sand it paint it
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    Re: Quick question for you guys! (USP help needed)
    Sideskirts, or door blades?
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    sideskirts refer to the pieces that run length-wise beneath the doors. they are the same for stock or usp.
    what you want are the doorblades, which are different...
    "endcaps" = dealerspeak for, (here it is used in a sentence) "bend over i'm gonna shove this "endcap" up your ass."
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    i think he means the corner piece that is right in front of the rear wheel well. the lower side skirt on the usp has one long piece and then the corner piece.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    May 17 2007
    Like Toaster said, the sideskirts are the same. Door blades are probably what you're after. That said, the USP ones are minimally different than the standard ones. The S4 ones are where it's at.
    -Ryan
    Maestro Tuned
    Oct 21 2007
    The USP sides are not different from stock? I was told otherwise, I know I am not looking for the doorblades even though I know those are different.
    I heart wagons.
    Sep 16 2005
    long island, ny
    Quote Originally Posted by diztek View Post
    so does stock.
    Sep 16 2005
    long island, ny
    Quote Originally Posted by michgo View Post
    would you like the place of origin?
    "endcap" - derived from stealerships.
    alternate pronunciation: "you're-NOT-sure...let-me-SCREW-you."
    "endcap."
    Oct 21 2007
    Quote Originally Posted by toaster View Post
    "endcap."
    Yikes. Well i currently have Reiger sides which are going away soon so I have no OEM pieces left. Will i be needing to buy the endcap as well?
    And USP sides are no different from stock
    I heart wagons.
    May 17 2007
    USP:
    Standard:
    The "end cap" they are referring to is that piece of the side skirt at the end near the rear wheel.
    -Ryan
    Maestro Tuned
    Sep 16 2005
    long island, ny
    ahhh, cmon dude!
    how much clearer can i be for you...i tried to be thorough to help a brother out...there is NO difference in the skirts. the flat blades slide out and can be easily swapped for usp blades by simply unscrewing 2 screws.
    i built my USP from scratch...from bone stock.
    how do i reach these kEEEEEEds...?
    one more attempt:
    the ONLY difference is the BLADES, not the SKIRTS.
    Oct 21 2007
    So the skirts arent different?
    So then i understand. I guess I am ok to buy regular sides. No point in buying USP sides unless i want a 2piece.
    I heart wagons.
    Sep 20 2004
    Paradise Valley, AZ
    id get the s4 blades if you are buying blades. and for some reason they are cheaper than the usp blades.
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    Yeah...the S4 blades are more "there" than the USP blades, which hardly seem worth the trouble (unless you want to do a totally legit USP conversion).
    The skirts are definitely the same...but if you had to buy new ones I would look at Caractere also. I think they look the best on the B6.
    Cheers,
    boy412
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    ROFL!!!, LMFAO!!!
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
