Results 1 to 17 of 17
Thread: grille removal
    Senior Member Two Rings 00a4's Avatar
    Apr 07 2008
    parts
    NOVA/ NC
    grille removal
    does anyone know how to remove the grille?
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Re: grille removal
    You just need a flat head screw driver. You pop the hood and start depressing the little tabs holding it in. Eventually as you get them free it will start to pop out. You have to work it a little with your finger tips and the screw driver.
    Registered Member Two Rings snyper55's Avatar
    Jun 20 2007
    2001 A4 1.8TQM
    Re: grille removal
    I used a flat head and cardboard. Just pop each tab and insert a piece of cardboard into each tab(so it doesnt lock back up). Then just push the grille from the inside.
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    Re: grille removal
    I would suggest u get a honda haha, removing the grill is easy as hell, a lil kid can figure it out haha.
    anyways as people said use a flat head, be patient.
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Aug 19 2007
    central oregon
    Re: grille removal
    it might be stuck if its old u just have to push really hard. ignore any popping cracking breaking sounds.
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    Re: grille removal
    Quote Originally Posted by airy52 View Post
    Not the best advice if you plan on using the grille again since the tabs are fairly easy to break. I like that cardboard idea and I wish I thought of that when I did mine. I think it would help if you did one on top and then the one below that and just moved across that way, if you do the top first and then the bottom it will probably be more of a challenge. Don't forget there are some on the sides also.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    Re: grille removal
    i juat got a bunch of flat head screw drivers and stuck each one behind a tab. once you et all the ones on the top it'll pull out. just make sure you collect all the screw drivers before you start the car ;)
    Jun 20 2007
    2001 A4 1.8TQM
    Re: grille removal
    Quote Originally Posted by Bic-Ball View Post
    Sounds good too but if you dont have enought flat heads just do what i did.
    Use one screwdriver and a one old shoe box
    Aug 19 2007
    central oregon
    Re: grille removal
    i forgot, sarcasm is hard on the internet
    Active Member Two Rings TonyTone5390's Avatar
    Sep 11 2008
    1998 a4 2.8L
    WA state
    Re: grille removal
    Can anyone point out the clips that need unclipping?
    I was strugglin :/ haha.
    J DILLA
    CHANGED
    MY LIFE
    Apr 20 2009
    2001 A4 Avant 1.8TQM
    Re: grille removal
    they're at the top of every other vertical piece of the grill. they're about 2" wide. the top pops out then tips forward. you don't touch the ones on the bottom until you have to line it up for re-install.
    Sep 11 2008
    1998 a4 2.8L
    WA state
    Re: grille removal
    Awesome thank you!
    Is it hard to put back in? Or is it just, line it up and push it back in?
    J DILLA
    CHANGED
    MY LIFE
    Dec 05 2007
    Re: grille removal
    Be sure you have the hood release latch in position on the grill before closing the hood.
    Sep 11 2008
    1998 a4 2.8L
    WA state
    Re: grille removal
    haha oh god. yeah good point. I don't know why I'm stressing so much over this.
    Noob much?
    J DILLA
    CHANGED
    MY LIFE
    Senior Member Two Rings allspooledup's Avatar
    Nov 16 2008
    Bay Area CA-->Jacksonville NC
    Re: grille removal
    I have removed the grill numerous times with out any tools. i push in the tabs with my fingers tilt the grill outward and pull it out.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: grille removal
    08 S4- Stock SOLD
    Established Member Two Rings AWD Mike's Avatar
    Oct 19 2008
    '14 Tacoma TRD Sport | '14 SQ5 Prestige
    Richmond, VA
    Re: grille removal
    Seriously... I just used like 5 flat heads lol
    Just push them down and then push the grill out. Since it was the first time mine had ever come out, it made a lot of noise, but nothing broke.
