Results 1 to 32 of 32
Thread: DV questions
    Senior Member Three Rings 03CrysBlueB6's Avatar
    May 12 2008
    washington
    DV questions
    tried searching but with no luck. i tallked to my local shop and i told them yeah im looking to replace my dv and honestly i would like a little "whoosh" or "psh" and they said dv should not make noise?? is that true??
    are there any DV's out there that are safe to run off of our engines and stock turbo that can make that noise? also i dont mind adding an intake tiher.. what do you guys suggest. they suggested an R1 but there have only been "so-so" reviews about that.
    B5 A4 - silver [gone]
    B6 a4 - Crystal Blue [current]
    FS: B6 A4 sport struts with about 30k on them
    WTB: S4 or USP front
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    Established Member Two Rings A4DJ's Avatar
    Apr 22 2008
    '05 S4
    Colorado Springs
    Re: DV questions
    Couldn't have searched too hard... this is on the main page.. about 7 posts below yours at this point: http://www.audizine.com/forum/showthread.php?t=212446
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: DV questions
    If you want sound, your going to need two to three things.
    Chip + intake + DV
    I have a video if you want to see how mine sounds, but its not the best of videos.
    I have a carbonio intake with a forge 007 installed in reverse and its perfectly safe to run this way.
    May 12 2008
    washington
    Re: DV questions
    yeah let me see the link to the video! thanks
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: DV questions
    I first noob mod was the Evoms intake and it will give you the sound you crave... you can hear the car drawing air in as you shift throught the gears... I have the 007 Forge DV but installed the normal direction. The chip isn't going to give you any sound but will make the car more enjoyable to drive... beware though, once you chip you will want more...
    Dec 19 2007
    York, PA
    Re: DV questions
    ^you will always crave more power [q the tim taylor manly grunt]
    Registered Member Two Rings ComfortRacing's Avatar
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    Re: DV questions
    i personally after reading everything....twice! i ended up buying the R1 and the stage 1+ software, and love it. all i have for an intake is a k&n drop in but when boosting at around 20psi i can here it a bit. i am currently working on a new intake so i should here it no problem. also the R1 helped by driveability big time. it is a very fast acting valve.
    2002 A4 Quattro 5-speed, KO4, SPP Ported/Polished Turbo Manifold, ATP test pipe, APR ko4 tuning, APR injectors, APR R1 DV, Front mount intercooler, H&R sport springs/Bilstein sport shocks, Neuspeed snubber mount K&N, Blackedout grille, Badgeless rear.
    To Do's:
    -APR Sport exhaust
    -Porsche seats, brakes and wheels
    -Recarro Baby seat =)
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    Re: DV questions
    pondside is right, i bought the stage 1 chip on a saturday, stage 1+ a week later and now i am upgrading the turbo...chipping is the gateway drug of tuning!
    To Do's:
    -APR Sport exhaust
    May 12 2008
    washington
    Re: DV questions
    yeah i know i know... there is nthing wrong with craving more though!! still waiting on that video clipQ i jsut want something that sounds nice.. but isnt going to harm my car
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: DV questions
    Check Youtube there are a few different clips on BOVs/DV/intakes on our cars..
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Re: DV questions
    I started with the R1 with the APR Stage 1 but i was like you and wanted a little more sound...
    http://youtube.com/watch?v=o6X95jDZ2VM
    thats a clip of the Forge SPLT-R dv/bov i bought. it recirculates air and releases it atmospherically so you get the sound and performance. this clip was made with the stock airbox
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Mar 12 2008
    CHI-TOWN
    Re: DV questions
    i sorta bootleg mine i gues but this is a very ceep way to get that sound u want i bought a cone filter and connected it to the maf to tip u get the nice sucky sound with a load coughing noise i will go take some viedo and post them for you
    [IMG] [/IMG]
    [IMG] [/IMG]
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: DV questions
    ^^ not bad, looks real similar to my overpriced EVOMS but you may want some sort of heat shield and remove the old air box
    Mar 12 2008
    CHI-TOWN
    Re: DV questions
    yea i will probly buy some pipeing and move it alittle more but i was planning on buying or making the heat sheild that is realy good but i was impressed on how lou my dv got and the amount it sucks for such low boost the rest of the air box is there cuz i sill conec the ram duct so i stil lget cold air from the wind force i hope this picture explains it
    Mar 12 2008
    CHI-TOWN
    Re: DV questions
    here is what it sounds like in side not bad for stock dV
    http://www.youtube.com/watch?v=WUmbBJa6PUc
    <object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/WUmbBJa6PUc"> </param> <embed src="http://www.youtube.com/v/WUmbBJa6PUc" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: DV questions
    Now I see your method good stuff.. custom is always fun
    Sep 07 2007
    San Francisco, CA
    Re: DV questions
    Quote Originally Posted by A13ART View Post
    [IMG] [/IMG]
    [IMG] [/IMG]
    Hey dude, what size/type of filter is that going into the secondary air hose? I need one of those!!!!
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: DV questions
    heres my videos, there crappy, dark and taken with my cellphone so meh.
    video from outside
    http://www.youtube.com/watch?v=69SJC-8kttc
    video from inside
    http://www.youtube.com/watch?v=-6MuG...eature=related
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: DV questions
    Quote Originally Posted by pondside36 View Post
    Chip=more boost. More boost=more air to get out. More air = more sound
    May 12 2008
    washington
    Re: DV questions
    is that a safe way of doing it? putting a filter on the MAF will it throw codes?
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    May 12 2008
    washington
    Re: DV questions
    has anyone else ever done that? i dont want ot end up ruining my car
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    Mar 12 2008
    CHI-TOWN
    Re: DV questions
    its a three inch filter and the mas airflow is ethier 2.5 or 2.75 but i tape the ouer part of the mass air flow for aight seal.
    and for the other quesion i left of the maf and i threw a cheack egin light then i earsed it and conect the mass air flow and got no cheack ain u have to make sure u have some cooled air running to ur intake like how i still have that air vent and i amm gitting a heat shield soon fro mthe guy on our forum bu it cheep and what ur looking for is sound that is the way to go i got a pr r and will be putting that on soon once it comes in so i gues that will make it little lounder and then comes test pipe and lines and chip then rest of the exshaust and the turbo upgrade
    Dec 06 2007
    Re: DV questions
    i think i got a migraine from AudiBama's vid haha! j/k! i'll take a vid this week sometime i have a 710N and it is freakin loud man!
    -Kirk
    BetaAlphaTau Member #58
    May 12 2008
    washington
    Re: DV questions
    how did you get it to be loud.. intake? or what
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    Sep 07 2007
    San Francisco, CA
    Re: DV questions
    I meant the smaller filter you have in the picture, what size is that one?
    Senior Member Two Rings Tacoman_Si's Avatar
    May 28 2007
    2004 b6 USP
    lake stevens
    Re: DV questions
    i have the turbosmart hybrid Diverter. It is set to full recirclate and it still has the whoosh sound.
    Dual Port
    Part Numbers:
    FG-BOV-KTDP20 (20mm), FG-BOV-KTDP25 (25mm)
    Here is the link.
    http://www.turbosmartonline.com/index.php?id=44
    2004 white 1.8T USP 35% tint// CF B-pillars//Milltek exhaust//milltek hi flow cat//Turbo Smart DV//19 inch VMR 714's//2500k yellow fogs//Clear Corner mod//B6 LED tails//RS4 sway//podi w/boost gauge//koni coilovers//AVIC D3 BT & IPOD//Alpine amp//Kenwood 12" DVC
    Mar 12 2008
    CHI-TOWN
    Re: DV questions
    the smaller one i belive s called a breather but i don no the size on it but i belie it came from autozone me and my friends all have a small garage that has all our werid extra parts rom of our cars and peoples car one of use works at auto zone one of us works at pepbos so we get some parts like that from there but yea i should be geting the r1 very soon and i think my test pipe i wil be buying within a week cuz the guy opno the forums isnt getting back to me on his and i wanted 3 inch any ways
    May 12 2008
    washington
    Re: DV questions
    how mcuh did you pay for tat tacoman? and who did the install?
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    May 28 2007
    2004 b6 USP
    lake stevens
    Re: DV questions
    i found it on here never used for 100 shipped. i was going to do the install myself but my coilovers came about the same time and i had stage in kirkland do the complete install from coilovers alingment and diverter vavle for $280 after tax. 2 1/2 hours worth of labor. Hell since they had the car in the air it made sense to just have them do it.
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    Re: DV questions
    i run that setup w/ just a 3" filter on the maf but for no reason since i run full bov... as for runability, i have never had a problem with it...and i also took the factory heat shield off of the stock air box and put it between the cat and the filter and it's held there by an old school piece of coat hanger... cheap...yes... effective...about 70%... look good...not really.. overall, it's cheap, and it works pretty good for being free...
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Re: DV questions
    Quote Originally Posted by J-jizzle View Post
    I have APR 1+ and no sound. Just a boost leak from soo much boost the damn hose popped right off the new DV(my guess), so I have a constant hissing in boost, instead of alot of power that i should be getting. Make sure you clamp those mofo's on tight. Anyway, to the Original Poster, Just get in open air intake with a cone, like the rest of the people said. LLTek makes a real nice one if your willing to put down $300.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Feb 07 2008
    just the a4
    northeast pa
    Re: DV questions
    Quote Originally Posted by A4 KiDD 810 View Post
    hows that baileys workin out for ya??
