    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Sunroof controler rattle
    Havn't seen any post about this. I got a really annoying rattle, it rattles going over bumps and especially wheni have music loud. It goes right away if i hold it but i'm not going to be holding it all the time...anyone got the same issue and fixed it?
    Registered Member One Ring theone23's Avatar
    Mar 06 2008
    2.0t fwd b7
    Salt lake City
    Re: Sunroof controler rattle
    I have the same issue. Very interested if anyone has a fix
    Veteran Member Three Rings nycmalu's Avatar
    Apr 16 2008
    Rockland County, New York
    I was hoping it wasn't just me... Two 12" subs in the trunk, and I can't hear any music because of this ****ing rattle... I was just going to take it apart and stick some of that stuff you use to insulate the edges of a door behind it... Don't really know how to do it, but this is almost as bad as the seatbelt chime (which I got rid of after a week)...
    EDIT: Just found this picture on someone else's post, and I wanted to make sure we're talking about the same thing here...
    -Steven
    CONTROL ONE: Haha, don't toy with her emotions - that's my job.
    marty was here: listen. you are an amateur.
    Apr 14 2008
    Milton VT
    yea it's that...when i get back to the states i'm gonna have the dealer fix it cause it's annoying as F*** and you cant really appreaciate listenting to music or even driving quietly because of it
    Senior Member Two Rings gervi's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T
    Winnipeg, Canada
    Yea, I had the same issue, though it went away after awhile.. On my last oil change at the dealer I brought it up and they said that rattles weren't covered under warranty anymore and they were only covered for the 1st yr of ownership... So I'm probably just gonna open it up and put some tape on whatever is loose because when u actually put pressure on the panel it stops rattling. Though whoever goes to the dealership, post up here what they did to give all a better idea on the solution to this annoying rattle...
