Results 1 to 7 of 7
    Senior Member Three Rings asurugger's Avatar
    Mar 12 2008
    2008 Cadillac Escalade
    Phoenix, AZ
    Staggerd fitment
    can you use a stagggerd fitment on an s4? i was informed that you could? any thoughts
    2016 Audi A6 Prestige
    Veteran Member Four Rings mioStile's Avatar
    Sep 25 2006
    Re: Staggerd fitment
    Basically what it comes down to is peformance and quattro.
    First: Performance - The s4, with its beautiful, though heavy, front end tends to understeer a bit. When you run a wider fitment on the rear than in the front, you will increase understeer slightly.
    Second: Quattro - In order to keep your quattro in good running order, you have to make sure that the rolling diameter of your front tires and rear tires are within 5% of each other. It's been done plenty, and I've never heard of anyone having problems resulting from it.
    Consensus: With a staggered setup, you can get it to work, but you will sacrifice some performance.
    Current Iggnshn: 2007 4.2L 6 speed quattro S4. Neuspeed catback. 20x8.5/20x9.5 BBS RSGT. PSS9. USC license plate. always my work in progress.[/FONT]
    AMA
    Together we can all defeat 2.0T and 2.7T crime
    Ya, I'm that guy...
    Veteran Member Four Rings 10MPG's Avatar
    Oct 25 2006
    Current:
    Bay Area CA
    everything above + worse gas mileage.
    firsthand experience from current setup....
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    you can. search for capt obvious, he created a calculator on figuring out the correct tire sizes to run to stay within tolerances for your center diff.
    the homebrew'd s4
    Mar 12 2008
    Phoenix, AZ
    Quote Originally Posted by Overboostin View Post
    if im not mistaken the 08s changed to 40/60 differ's this year?
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    Quote Originally Posted by asurugger View Post
    someone said it was from 06 and up, but who knows.
    i run a staggerd wheel width setup, however i kept the tire size the same. front and rear, and i havent noticed a big increase in oversteer. i think a rear h-sport bar will take care of that though.
    Senior Member Three Rings Mello's Avatar
    Jan 07 2008
    '04 S4, '06 GSXR 1K, '06 Apex
    I went with 8.5" up front and 9.5" out back with a H sport rear sway. The way I see it, I'm never going to track the car or set up cones on the way to work so I can take some 90 degree turns @ 60 so it didn't matter to me.
    Staggered lips look sick on our cars to boot :)
