Results 1 to 19 of 19
    Veteran Member Three Rings HIS4's Avatar
    Aug 15 2004
    Mililani, HI
    Contact at Volxgerman for repair work.
    I'm thinking I'm going to give VG another shot and take my car there for some needed repairs. Who is a contact there that I can talk to? I got some really bad clunking and grinding coming from the front of my car. I suspect either the steering rack or the CV joint because my suspension and control arms are relatively new and the grinding happens when turning the wheel even at idle. I also need to replace my alternator and my accessory belt tensioner but I don't know if I'll do that all at the same time. I just want to get the griding thing taken care of for now.
    2011 Meteor Gray A4 Avant - Premium, AMI (retrofit), Bi-xenon (retrofit), Bluetooth, Homelink, VAG mods, TunerDomes.com LEDs, Revo Stage I
    2016 Sapphire Blue Porsche Cayman GTS - Still thinking about mods but not much needed...
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    Re: Contact at Volxgerman for repair work.
    808-593-0335 (Main #)
    [email protected]
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    if the clunking is present while at a stand still, check your steer rack bolts (12pt don't remember the size)... I had a similar problem a few years back on my B5 S4, a dealer quoted me at $250 to tighten a bolt, I did it myself for free...
    grinding may be your P/S pump, have you flushed it or had it flushed lately?
    just an FYI to check yourself, ESPECIALLY if you've already replaced your control arms...
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
    Veteran Member Four Rings AudiBoy808's Avatar
    Sep 28 2004
    99.5 A4
    Honolulu, HI
    You can talk to Aaron or Desbie that's who I always talk to when I go there.
    99.5 silver A4
    FI CF hood | Eurogear CF Euro trunk | Eibach Pro-St coil overs | Crimson K6 | Kerscher frnt | Avant garde sides | RSR Rear | Vibrant exhaust | Silver CF rear seat inserts |
    Apr 16 2005
    Pearl City, Hawaii
    Mine makes noises if I turn the steering wheel all the way.
    Aug 15 2004
    Mililani, HI
    Quote Originally Posted by PSYC0TIC ONE View Post
    Thanks. I may try to check it out this weekend. I haven't had the PS fluid flushed but my PS pump has been making squeeling noises for years now. I've always made sure the fluid is topped of so maybe it finally bit the dust.
    Aug 15 2004
    Mililani, HI
    Can you describe where the rack bolts are? I'm trying to look through the Bentley but haven't verified the location yet.
    Oct 19 2005
    Virginia
    Quote Originally Posted by HIS4 View Post
    i'm trying to picture it in my head...
    for mine, the one that was loose was under the battery (removing it was the biggest pain about the whole process)...
    the best way to test to see if you have a loose rack is to get the front wheels off the ground and grab a front tire at 3 & 9 o'clock and rock it back and forth, watch the tie rod, if it moves up and down, your rack is loose... side to side is suspension...
    -Cliff
    Current:
    Aug 15 2004
    Mililani, HI
    Crap! I actually already did that test to see if it was a tie rod or suspension issue. There was no play up and down or side to side.
    Oct 19 2005
    Virginia
    can you hear the clunk while doing the test? if there is NO play and you still here it have a buddy see if he can watch for "moving" parts up near your steering rack while you move the wheel...
    -Cliff
    Current:
    Active Member Three Rings Thomas@TAI-VW's Avatar
    May 20 2005
    B8S4 Chariot of the CLODS
    Hawaii
    dude its only going to get worse since you have 150K + miles now (?) Time to dump that thing and get something with less miles/more reliable.You are having a lot of hassle keeping a 250hp car on the road this long.Get a 2.0t B7A4,chip it and it wll be faster,better mileage,more reliable,cheaper for repairs/maintenance,and it won't have 150K miles!
    S4's are money pits.....they can be made incredibly fast,but then the pit gets deeper.You are also still on original turbos right?Wait until those blow........sell it I tell you,best advice you will get right there....
    2012 S4,6MT. Steering wheel/4 rims & tires/seatbelts/windshield wipers/41 psi in front tires/40 psi in back tires/CD player/AC/sunroof/oil level=full/coolant=full/no CEL/glovebox/no car payments/dusty brakes/lowbeam/high beam/turn signals/small nick in the bumper from a stone about 1/16" in dia. about 4 " below the headlight/gas in tank/clutch-brake-gas pedals.
    Veteran Member Four Rings HIstateS8's Avatar
    Feb 16 2005
    Aiea, Oahu, HI
    I loved my B5 S4 to death, but keeping it in tip-top shape took a lot of work and a lot of money and the sad thing is, it still gave me problems. I'm sad that I had to get rid of it. If you are planning to sell it, sell it asap or if you plan on keeping it, be prepared to dig deep into your wallet.
    -Brandon S.
    2002 Metallic Black //S8
    Aug 15 2004
    Mililani, HI
    Quote Originally Posted by Thomas@TAI-VW View Post
    I'm already shopping but I figured I'll need to get the really obvious stuff fixed before I try to sell it.
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    dude its only going to get worse since you have 150K + miles now (?) Time to dump that thing and get something with less miles/more reliable.You are having a lot of hassle keeping a 250hp car on the road this long.Get a 2.0t B7A4,chip it and it will be faster,better mileage,more reliable,cheaper for repairs/maintenance,and it won't have 150K miles!
    telling it like it is. i take it from the guys already been through it...gino, brandon, jesse to name a few. i considered one after my b6 a4, but knew to make it worthwhile to enjoy the car, needed to set aside an extra 10k for it.
    good luck.
    Aug 15 2004
    Mililani, HI
    Thanks for the advice everyone. At this point, shopping for a new car seems to be the best but I'm not sure if I should just trade in the S or try to sell it. Selling it would mean I would need to fix it. Trading it in wold probably get me less money for it but I could also sell off the mods to make some of that up.
    Here's the shopping list of cars so far.
    BMW M3 sedan
    BMW 535
    Lexus IS350
    Lexus IS-F
    Lexus GS350/460
    Audi A6
    Mercedes C63 AMG
    I have yet to drive any of these except for the IS350 and GS350 so I'll need to get out there and check them out so I can narrow this list down.
    Oct 19 2005
    Virginia
    BMW M3 sedan
    BMW 535
    Lexus IS350
    Lexus IS-F
    Lexus GS350/460
    Audi A6
    Mercedes C63 AMG
    if you want to squeeze every penny out of the S4 sell it privately... If you are just trying to get out from underneath it, just trade it in...
    -Cliff
    Current:
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    BMW M3 sedan
    BMW 535
    Lexus IS350
    Lexus IS-F
    Lexus GS350/460
    Audi A6
    Mercedes C63 AMG
    Looks like you're going VIP to me :)
    BAGS and lip FTW!
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    Apr 16 2005
    Pearl City, Hawaii
    If you trade it in the dealer will give you half of what its really worth. I would go private party, then buy an M3
    Feb 16 2005
    Aiea, Oahu, HI
    Yup, buy the new A6 and bag it!
    -Brandon S.
