Results 1 to 2 of 2
    Feb 19 2008
    Bellefonte, Pennsylvania, USA
    Angry bad starter, car shut off while driving....
    So I'm driving along and the engine just dies. the clutch was out and i tapped the gas and nothing... It got towed to the house, I vag-com'ed it and didn't get any codes accept a voltage too low for the airbag. I smelled how electronics/wires and saw smoke from over top the starter. watched the started w/ friend turning the key on and off ignition. after a couple clicks, I have smoke comming from inside the starter right under where the relay wire connects on.
    I understand that means I need a new starter & relay. However, could that short or whatever it wrong w/ it cause me to loose all power as I'm driving down the road? Prior to today and this morning, the starter has started the car quickly every day all day w/ out problems.
    Also could something else have caused that to burn up or did it probably just fail on it's own?
    Thank all who may be able to help!!!!!!
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Re: bad starter, car shut off while driving....
    could've
