Results 1 to 12 of 12
    Veteran Member Three Rings A4 JooN 2.0T's Avatar
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    rs4 sway and underdrive pulley
    omg i just got em installed.........[O_O] god i love it......sounds like a whole new engine minus the wasting gas lol but yea the pulley kicks ass
    2007 B7 A4 2.0t Qtip Brilliant Black on Black -=- Revo Stg 2/SPS2 -=- Milltek Catback Labree Quads -=- Eurocode Testpipe -=- K&N Filter -=- Forge DV -=-RS4 Rear Sway -=- ECS Quick Spool Pulley -=- Neuspeed SS -=- 20% 3M Tint -=- Lamin-X Yellow Fogs -=- LED UV Blacklight Interior Lights -=-O.Z Ultraleggera Black w/ Yokohama S.Drives
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    Angry Gerbils
    west of the equator
    Re: rs4 sway and underdrive pulley
    Does the pulley make a difference? I've heard everything from it being awsome, to not being worth the money. Did you install it or take it to a shop? If you took it to a shop how much for install
    '06 Dolphin Gray A4 2.0T
    Motoza Tuned EFR
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    Quote Originally Posted by viperdsa View Post
    took it to a shop and he charged me $50 cuz i know him....it does make a difference not a significant gain but you can definitely notice throttle response one thing is the gas LOL i was going to put in 2 gallons of 100 octane but i forgot to damn...
    Registered Member Four Rings Noffy's Avatar
    Sep 06 2007
    Audi A4 2.0T, Forester 2.5xl
    Portland Oregon
    What kicks ass about it? Or was that sarcastic?
    2005.5 A4 2.0Tq Quartz Grey
    Looking to purchase a euro car that I can learn to work on, and eventually take to the track for recreation days. What is a good car to start with?
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    what is the pulley? does it make a significant difference? if its that cheap and that good why are more people not doing it?
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Active Member Two Rings ringsbythebay's Avatar
    May 19 2008
    Quote Originally Posted by a4dc89 View Post
    It is a lightweight/underdrive crank pulley. I put some on my 1.8T in the past. It lightens the rotational mass on the engine thus letting your engine rev up easier and quicker. For a turbo car that means you will be getting into boost faster.
    Many people don't do them since the crank pulley may or may not act as a balancer for the crank (depending on the opinion of the day) and may cause wear/damage issues. Most people that have run them have not had any problems. You will feel like the engine gained some horsepower due to the faster revs.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    seeing im under warranty, not touching engine parts that could possible void my entire engine
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    Quote Originally Posted by vtracer20 View Post
    ^^^ [O_O]
    AS If *flashing or Chipping* doesn't do that already ????
    and Lowering... and just about anything .....
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    They cant void your warranty for lowering or anything that doesnt effect the engine directly. a chip is usually not traceable so not a whole lot to worry about. just but it in stock when you got to the dealer. the pulley might be more noticeable
    All go no show
    May 19 2008
    Just to answer some of the other questions, yes the pulley should make a significant difference. The drawback to an underdriven pulley is that your AC might not be as cold and your battery might not charge up as well due to both the AC compressor and the alternator not rotating as fast (usually 10-20% less). Some companies make just lightweight versions that are the same diameter as the originals so you don't have that problem.
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    Quote Originally Posted by ringsbythebay View Post
    nicely put but whos needs ac anyways??
    May 19 2008
    Quote Originally Posted by A4 JooN 2.0T View Post
    Oh I am a fan of the pulleys. Just roll down the window
