Results 1 to 8 of 8
    Mar 20 2008
    Italy
    European A4 b7 3.0 tdi >>> Rs4 b7 front BBK?
    Does anyone know if the Rs4 b7 front braking system (365x34, 8-pot calipers) is a direct fit on a A4 b7 3.0 tdi??
    Do i need any caliper bracket redesigned?
    I do have 18" wheels.
    Thank you,
    Andrea
    Active Member Four Rings
    Nov 19 2006
    Ibis 07 A4 S-Line
    San Fernando Valley, CA
    Re: European A4 b7 3.0 tdi >>> Rs4 b7 front BBK?
    I don't have the answer to that...
    BUT
    Does your exhaust valence have exhaust cut outs or is it smooth?
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    8E0 615 107
    8E0 615 108
    8E0 615 301 AB (2)
    8E0 615 311 D (2)
    8E0 698 151 H
    About ~$2300, and for that money there are better setups.
    -Kris
    Mar 20 2008
    Italy
    Maybe in the US.
    But you don't consider i come from Italy, and here in Italy the cheaper BBK upgrade for this car costs 3000€uro.
    The Rs4 b7 setup costs more or less 2000€uro.
    However, do you know if it can be fitted without mods on the A4?
    Thanks
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    i think it should fit...but as for the wheel you would need a different offset.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Senior Member Three Rings Grassmonkey's Avatar
    Sep 23 2006
    B7 A4 DTM
    The Netherlands
    To get the 8-pot caliper to fit you need;
    caliper bracket
    splash shield and some other parts.
    And they'll fit on any B7. Take a look on ebay.de they have whole conversion kits available, so you can see what you need at least.
    2006 B7 A4 DTM
    Mods: RS4 Pedals, RS4 side mirrors, RS4 grill, S4 Blades, PSS9's, RS4 rear swaybar, 034 HFC, Milltek Exhaust, ATP GT28RS, S3 Injectors, HPFP, Rennworx RSL 19x9
    Mar 20 2008
    Italy
    Thaaaaank you ;)
    Nov 19 2006
    Ibis 07 A4 S-Line
    Any word on the exhaust cut out valence?
