Results 1 to 8 of 8
Thread: Stg 3 gauges???
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    Stg 3 gauges???
    So was looking to get a boost gauge for the car, but thinking ahead to stage 3, what else would I need? I was thinking the air-fuel ratio gauge would be good to see if the car is running lean or rich, that what most guys have or do you get by without it?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Stg 3 gauges???
    for an off the shelf stage 3 kit you dont necessarily NEED a wideband a/f gauge... if youre going to test/tune id definitely recommend it tho.
    i get by without it but i tweak carefully and log a lot
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Stg 3 gauges???
    Boost and wideband AFR
    Deactivated Four Rings
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: Stg 3 gauges???
    ^^ /thread
    Dec 06 2007
    Calgary, AB, Canada
    Re: Stg 3 gauges???
    I'm really not a fan of the look of a steering column mounted gauge, but I would recommend getting a boost gauge and an AFR WB gauge. Here's my setup, a little more subtle...
    Apr 10 2008
    Re: Stg 3 gauges???
    how did you mount ur a/f one?
    Dec 06 2007
    Calgary, AB, Canada
    Re: Stg 3 gauges???
    Heavy duty double-sided mounting tape. I ran the wires under the bolster that is directly below the gauge...
    Jun 11 2005
    Vancouver, BC
    Re: Stg 3 gauges???
    You can always try putting the VEI dual unit in the vent.
