Results 1 to 9 of 9
Thread: summer tires!
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    summer tires!
    summer is coming and i have some garbage tires. tires i am looking for need to have good wear, great grip. (looking to do some auto-x, and will be for dd'ing)
    I will shoot down my list so far (no order)
    Toyo T1R
    Falken Azenis Rt615
    Bridgestone Potenza Re01r
    Yokohama ADVAN Neova AD07 - Expensive, so probably wont get them
    Goodyear Eagle F1 GS-D3
    any one have experiences with any of these? i have a friend running the GS-D3 and swears by them. I have heard the T1R is a bit better because while it has a similar tread pattern it has solid blocks on the edge of the tire for better cornering.
    I have a feeling the Azenis will wear quicker as i believe it is a softer compound.
    Lastly, i have a feeling the potenza and neova are going to be very similar, so i would just get the cheaper of the two (potenza)
    any tips?
    ThorTechnik.com
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Re: summer tires!
    Goodyear Eagle F1 GS-D3 FTW!
    I don't run them on my s4 but on my dad's lightning. I wish I did though... My dad got about 20,000 miles on his and that was with a lot of abuse. Lots of burn outs .
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: summer tires!
    I've heard that Potenza has great tires (RE050?). Do not get the Falkens (IMHO). I've had Yoko ADVAN ES100s on my RSX-S. They are extremely sticky.
    I can also recommend General Exclaim UHPs, which I have. They have never lost traction in all the time I've had em.
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    Re: summer tires!
    They all look like good options..
    But have you thought of the BFG KDW 2?
    I have those on my S and they do excellent...
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: summer tires!
    The Falkens will wear out fast and seem to lose some of their grip once they heat up. I ran those on my S for a while and later switched them to my Jetta because they were wearing out too fast for my taste.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Dec 06 2007
    Calgary, AB, Canada
    Re: summer tires!
    Kumho Ecsta SPT (best bang for your buck IMO) or MX.....
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Re: summer tires!
    wear and grip are polar opposites. You will have to sacrifice one for the other. Why not get a cheapo set of wheels with some kuhmo 710's and put some good tread life tires on your dd wheels?
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    Re: summer tires!
    Emil, I am currently running the Falken RT-615 and I have to say I am impressed. My last High performance tire was the Goodyear F1 and I got about 25K out of them, towards the end of their life they got noisy but they certainly hoooked up at the track and on the street (Not so much in snow, in fact not at all). I have heard things that aren't positive about the T1-R, the F1 are good in my book but really exspensive, The RT-615's I picked up for $130 a tire 235/40/18 and they the stickest tire I've had. Potenza's are good in my book haven't been in a S4 with them yet. I always wanted to try yokohoma. Get the RT-615's they only got 200 Treadwear so if you are lucky you can get 10K out of them.
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Registered Member Two Rings vladbe's Avatar
    Jun 16 2004
    2002 Audi S4 casa white
    Washington
    Re: summer tires!
    Ps2's Ftw
    2002 S4 Casablanca White
    2000 540i 6 spd
