Results 1 to 24 of 24
    May 23 2007
    sfbay area
    boost gauge light stays on....
    I tried hooking up my vdo boost gauge yesterday and decided to test the wires first. I grounded the boost gauge to that bolt right above the fuse box and connected the power wire to the 75X terminal. After doing that i found out my boost gauge led stayed on even when the instrument lights were off. Anyone have an idea to why this is happening? oh and im using 22 gauge wires...
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Re: boost gauge light stays on....
    Its because your hooked it up to a constant power source. Hook it up to the light switch 12v supply so it goes on when you put your lights on.
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Senior Member Two Rings akordboy's Avatar
    Feb 24 2008
    B6 A4 1.8tQ 6-sp
    York, Pa
    Quote Originally Posted by fikes View Post
    +1
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Parking light wire is located behind the driverside kick panel. If you have a 99.5+ you can hook it up to the vent light wire.
    Senior Member Three Rings Just Quaff's Avatar
    May 11 2007
    01 A4 1.8TQM
    Hey, I have been meaning to do this for some time now. Can you point out to me where the vent light wire is at?
    18" VMR RS4's Hyper Black | Samco Diverter Valve | ATP 3" Test Pipe
    REVO chipped | Koni Adjustable Coilovers | 19mm Neuspeed Rear Sway
    AWE Vent Pod Boost Gauge | Seat Cupra R Front Lip | Painted Lowers | S4 Side Skirts
    2.5" Custom Cat-back Exhaust to Magnaflow 12158 | 6000K HID's
    Veteran Member Three Rings d_maniac's Avatar
    Sep 16 2006
    99.5 A4 1.8T Q, 2004 A4 1.8T
    Bronx, New York
    it should be behind the vents use a flat head to pull em out
    Dec 05 2007
    Just wrap the wire around the fuse for the headlights. That is what I did. I went with the AWE instructions at first also. I read stories of people having thier vent lights short out on them for splicing the gauge lights into them, the only reason I did not do that myself.
    But if you do decide to go the route of tapping into the vent wire (which I don't recommend), you can't miss it. It is the only cable that does not permit you to remove the vent housing completely (meaning it is the only cable attached to the housing).
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Don't forget you can also hook it up to any one of the keyed power source posts on the Relay Panel behind the lower dash panel. That is if you want it on anytime the key is on. Otherwise you can get to the light switch harness at the bottom of the steering column as well.
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    The 75x terminal activates power when the car is on, or key in acc. mode. It's not a constant power source.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    I meant it has constant power when the car is on. There is real limited connections that have constant power when the car is off.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Tap it into a wire coming from the fuse box.
    Look at the side panel to decide which line to tap.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Or you can use the radio illumination wire and it will dim with your dimmer switch.
    I did this and it works/looks great.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    This what I did with mine, and I'm happy with it.
    Jul 07 2004
    socal
    Quote Originally Posted by Just Quaff View Post
    Pull the fuse panel off of the side of the dash and the light wires for that vent will be at the very top just behind the vent.
    May 23 2007
    sfbay area
    Quote Originally Posted by biketsai View Post
    So youre saying i can tap into any wire from the fuse box? I have an '01 quattro by the way.
    Quote Originally Posted by audinutt View Post
    -richard
    Where is this wire located at?
    Dec 05 2007
    Not any wire (fuse). If you want it to go on only when your other lights (headlights, day lights) you have to wrap the gauge wire around the fuse specified for that unit. You can warp it around the fuse for the daytime running lights and have it come on when you use that. Or wrap it around the fuse for the headlight unit, which I did.
    I had this same problem couple weeks ago. Fixed it in maybe 2 min. Link.
    Pic of where I hooked mine up to (pictures always makes it easier ):
    It is the white wire. The red one is for something else.
    May 23 2007
    sfbay area
    Oh i get it :). Thanks for the pic.
    Dec 05 2007
    No problem
    Jun 20 2007
    2012 JSW TDI
    Raleigh, NC
    -richard
    yeah, i tapped mine off the dimmer wire going to the cluster.. iirc it was gray/blue
    May 11 2007
    01 A4 1.8TQM
    Thanks Mike! Your a hero. Saw your latest thread with the battery relocation and kill switch. lookin good uber jealous
    Stage 3 Forum Advertiser Four Rings VMRSport's Avatar
    Apr 25 2008
    Irvine
    I usually just tap it into the headlight switch. Turns on when I turn the parking lights, etc on.
    This box does not currently receive PM's. Please direct all inquiries to Charles (VMRWheels) or Peter (Peter@VMRWheels).
    B5/B6 Audi A4 Test Pipe w/ Heat Shield
    VMR Sport | Integrated Vent Gauge Kit
    B7 Audi A4 Test Pipe - $69.99
    Veteran Member Three Rings chimchongdlight's Avatar
    Jan 02 2007
    Bay Area to Sacramento Ca
    so if u wrap the wire around one of the fuses, u mean literally wrap it around the fuse then plug it in correct? and if u do that, does that mean u will have to upgrade to a bigger amp fuse?
    Dec 05 2007
    Just make sure when you wrap the power for the boost gauge light, there is metal on metal contact. But yeah, just wrap the fuse (metal on metal) and plug the fuse back (fuse must be properly seated back in slot).
    The bulb for the boost gauge is only like 3-5 watts. The total Volt Amperage for the headlight circuit is rated for more than than. Figure the bulb alone is a 55 watt bulb (OEM Halogen) for the headlights. When Audi rated the circuit, they took into consideration the power it takes to start the circuit and run the 55 watt bulb (and the high beam bulb). It would be ok as that 3 watts for the boost gauge bulb is nothing.
    Jul 07 2004
    socal
    Quote Originally Posted by chimchongdlight View Post
    You wrap it over the metal tab so that the wire goes upward out of the slot where the fuse goes into. Only bad thing is that will force the tab inside the slot much larger and the fuse might pop out, this is the ghetto way of hooking up a wire and not really recommended. The best way is to just put a ground eye onto your wire and hook it up to the correct spot under the dash which is marked with a 75x or you can put a male connector on the end and pop a pacman/T-tap connector onto one of the wires that are already coming off of the 75x spot.
